Old 01-08-2005, 06:56 PM   #1
Broken_down?
glove box stuck shut..
how do I get it open with ruining anything? The button will not go in to open.
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 01-08-2005, 07:08 PM   #2
71swb4x4
71swb4x4's Avatar
Does the button have a key hole? Some of the buttons locked, they use the ignition key to unlock them.
Otherwise try some PB Blaster or something similar and let it sit. That may loosen it up.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-08-2005, 07:19 PM   #3
Blue Beard
Blue Beard's Avatar
If it needs lubed, I prefer liquid graphite. It flows though leaving a non greasy film to help lube things. Then dries leaving the film to lubricate.
Oil based products just help draw more dirt in....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-08-2005, 07:25 PM   #4
vtblazer
vtblazer's Avatar
True enough but liquid graphite won't break down rust/corrosion if that's the problem.
vtblazer is offline   Reply With Quote
Old 01-08-2005, 09:26 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Sounds like something is jammed inside. You can try squirting lube in. First I would try pushing the button in while pushing against the door around the button to get the load off the latch. If all else fails you can cut the bottom out of the cardboard. The box is a $10 part.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-08-2005, 11:42 PM   #6
Willy Prost
I will second pushing the door closed while trying to get the button to respond. Mine sticks sometimes and that is all I need to get it to reconsider.
Willy Prost is offline   Reply With Quote
Old 01-09-2005, 12:08 AM   #7
woodrow59
OzarkHillbilly in Atlanta
I agree with Fred T, just keep messing with it,,,press the button in and out while pulling and pushing on the door. Maybe just hit the door "lightly" with the side of your fist. That little spring in there and the latch can get worn out. That's what I did on one of mine. Sometimes it takes a little patience.
After you get it open don't shut it !!! LOL No really,,,,replace it , they're cheap,,,,,or do like I did,,,,,,Put in a locking button from a Freightliner,, I don't know the part # but it came in a set of door locks for a big 'ol truck !!!! Wifey brought home some obsolete parts from work one day that were going to be trashed. Found a Bosch alternator ( it fits, just ai'nt figured out the wiring) and a couple of bags of lock sets that included one that exactly fits the glove box door. I've got a locking glove box with a Freightliner key,,,,,ya never know what might work on these trucks !!!!!
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
