power antenna question
have a 72 C10 i would like to put a power antenna on it. Has anyone on here done this if so what did you use for antenna and was there a lot of modifcations you had to do to make it fit.
collector of vintage rust
Classic heartbeat did this on there 67 panel project.Check out there website,and click on the panel project link.
Most of the time I use Cadillac antennas. Specifically the early 80s model Coupe or Sedan DeVille. Mainly bacause of availability. These are a front fender mount and have fairly small motor/case.
There are many universal kits though. You need a radio that has the wire to trigger it or you have to run a seperate switch for it. You need to make some kind of strap to the lower mounting point to keep it steady. Other than that it's no biggie. |
