01-09-2005, 01:41 AM | #1 |
Nose-high Blazer ride height disease
OK so my '70 has a 6/5.5" Superlift kit (springs F&R) and sits kinda silly... most lifted Blazers I've seen sit with a nose high attitude (I'm guessing because the lift manufacturers spec their springs for pickups, which sit tail-high from the factory). Who has corrected this and leveled their K5? How did you do it? Would you do it that way again? I'm thinking a Superlift 1.5"-2" Add-A-Leaf would work, but if anybody else has an idea....
Thanks, Adam |
01-09-2005, 04:56 AM | #2 |
I use ord 0rate springs.
Earl 68 2500 4x4 GMC Burb |
01-09-2005, 11:01 AM | #3 |
The LuvShack Garage
WELCOME 2 THE BOARD FROM WEST 10-UH-C
Mine Has A 4/6 Lift, Supposed To Be Level With The Top On
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-09-2005, 11:55 AM | #4 |
Check out GMTrucks.org
I also used ORD 0 rates to fix the problem. They are just lilttle 1 inch blocks really that help level it out.
My lift is a 4 inch tuff country from suspension connection. They automatically send you 4 inch springs for the front and 6 inch for the rear when you order for a 69-72 blazer. |
01-09-2005, 02:23 PM | #5 |
Has anyone noticed how bad Blazers handle nose-down??I`m asking because I`ve found nose-up gives better handling on the roads,especially rough ones.It feels like the rear just follows the front better.Kinda like a motor boat.It takes weight off the front steering which takes alot of pitch`n`roll out of the handling.Trucks,too.This has been my experience at least.I bought a`90 K/5 new and I noticed it sat nose-down.It was my wife`s family-driver and I wasn`t planning on lifting it.I took it to the spring shop and had it brought it up about 2".This made it level to maybe 1" up.What a difference in handling.Seems alot of lift kits on PUs leave a nose-up stance too.
01-09-2005, 10:50 PM | #6 | |
The LuvShack Garage
01-10-2005, 02:32 PM | #7 |
LUV2XCLR8 - FYI, your bio on GQ says Rough Country springs. I've seen you post you had TUFF Country springs before. I know you know these are different and its a toungue twister bt TUFF and Rough. No big deal, don't mean to trash just a friendly note.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
01-10-2005, 04:32 PM | #8 | |
The LuvShack Garage
01-10-2005, 05:47 PM | #9 |
I have an all spring 4" lift on my blazer with no butt hang at all.
4" in front, 4" in the rear, seams to sit pretty level. It's one of those "EZ Ride" kits. Although they sent me the wrong shocks with it. |
01-13-2005, 12:28 PM | #11 |
SKINNY TIRES RULE!
My '72 rides high in front. It has 4" front springs with rear blocks and helper springs. Leveling it out isn't high on my priority list though. My '69 rides level with 6" front springs and 6" rear blocks. If I were going to keep the '69, I'd probably want to swap in some rear springs with zero rates.
Aaron, you've done some trimming to your front fenders so you don't have rub issues, right?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
