Old 01-09-2005, 02:46 AM   #1
Nima
Blue 67
How long do they last
Hey everybody:
It's been a while since I post anything. I basically ask questions than answer anything since I am nery new in this truck world. Well, you never know, one day I may be able to answer something!. Until then, these are my new questions:
How long do some parts like power steering component and front suspention/brake such as spindles last? The reason is, I am investigating to do the upgrades. I am just evaluating to buy the component new and do the changes one system at a time or buy a 80's truck as donor.
another question, does 88 power steering box will bolt to my 67 c20? I know I have to dimple the frame for the box. By the way, anybody has a picture of a dimpled frame?
Thanks.
Nima is offline   Reply With Quote
Old 01-09-2005, 04:20 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My 72 has all the original parts on the front suspension and steering. Even the wheel bearings are original. The truck has over 400,000 miles on it. But it's hard to guess on how long stuff will last...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-09-2005, 04:27 AM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
this is the best pic i have right now. as far as the box i have heard that it is 69-87. make sure you have the right brackets for your motor though. as you can see by my pump it is not aligned right, i made my own bracket for the time being (that was like 8000 miles ago ) and if you use a newer box that has metric fittings then you are going to have to have a newer pump with metric as well. as far as the spindles, i have never heard of them going bad. i would change all bearings and raceways in the rotors though. ball joints and tierod ends too while you are in there.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 01-09-2005, 10:51 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Spindles last forever unless the bearings seize then they may go bad(because of scoring)But if they remain greased and they are properly torqued they should be good for a long long time,The other frontend parts will wear depending on the lube schedule and the use/abuse you put them thru.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-09-2005, 12:51 PM   #5
Nima
Blue 67
Thanks for inputs and the picture. This might be stupid question but if I dimple the fram like that, doesn't weaken the frame?!
Old 01-09-2005, 12:54 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
I'm with everyone else. As long as you pack your bearings well, grease everything, and put it back together right, the truck will outlast us all.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-09-2005, 03:24 PM   #7
68w/sbc406
68w/sbc406's Avatar
it might a little just from heating it up and cooling it down, but let it cool down on its own (dont put water on it) or it will make it more brittle
Old 01-09-2005, 04:39 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Originally Posted by 68w/sbc406
...if you use a newer box that has metric fittings then you are going to have to have a newer pump with metric as well.
That fitting in the back of the pump where the lines screws in simply unscrews with a 1 inch wrench. Swap the o-ring fitting into your old pump to match the new box and don't worry about swapping pumps.
Old 01-09-2005, 04:46 PM   #9
68w/sbc406
68w/sbc406's Avatar
good to know. thanks tex
Old 01-09-2005, 05:17 PM   #10
Blue Beard
Blue Beard's Avatar
More of a maintenance issue to me....just as anything else mechanical.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
