Old 10-23-2001, 10:17 AM   #1
BW71
Post Suspension Q's
I'm getting ready to replace teh bushings(rear control arms,panhard bar) and put new rear springs in. Anybody got any good tips and hints to make the job easier. I dont have access to a lift so I/ll be doing it in the driveway. Its a 71 lwb 1/2 thanks.
71 C-10 custom Deluxe
Leavenworth, Kansas
BW71 is offline   Reply With Quote
Old 10-23-2001, 10:25 AM   #2
Snyk
Smile
have got mine stripped down to do this yet, but some things I saw..
1.) put pushings etc in the freezer for a while.. makes the a bit smaller so go in easier..
2.) if using poly parts DONT grease them up to make them go in.. use the recommended lubricant.. (Silicon I believe).. otherwise you will get squeaks..
3.) Plan on it taking longer than you would think =p....
`72 Cheyenne Super LWB, 402/TH400, Coils in rear, Med Olive cab over Dark Olive Body and Wood insert trim..
Currenly being stripped down for a Frame Off fixer upper...
Snyk is offline   Reply With Quote
Old 10-24-2001, 09:46 PM   #3
BW71
Post
Snyk.. Thanks for the tips. I'm puttin the poly bushings in and I figured it would take longer than I expected just didn't want to belive it. Degreased and put liquid wrench on all the bolts and nuts to get ready. Gonna start tommorow. thanks again.
Leavenworth, Kansas
