Old 01-09-2005, 02:50 AM   #1
KSever
KSever's Avatar
Switching to a TH350 ?
Planning on changing from a Manual 3 speed on the 63 C-10 to a TH-350 out of a 76 C-10. My question is are the rear splines on the trannys for the driveshaft the same on these two? Or am I going to have to have the driveshaft modified to fit the TH-350?
KSever is offline   Reply With Quote
Old 01-09-2005, 10:45 AM   #2
64fleetside
More than likely the TH350 is longer than the 3 speed, you may have to shorten the shaft. Get an auto trans crossmember from 63-87 truck. Brian
64fleetside is offline   Reply With Quote
