Old 10-25-2001, 11:17 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Post Front Spring Interchangeable?
I'll post here as well. Are the front coils from all Blazers, Trucks and Suburbans interchangeable from 73-87? Given that the engines are the same. I am guessing the big block springs would give me a lift up front and a six cyl. spring would give me a little drop?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-26-2001, 08:46 AM   #2
Snyk
Red face
well using springs for a Larger/smaller engine would give you a dropped ride height, but the spring rates would be all screwed up... Ie. BB springs on a 6 Cyl would be stiff as hell, and 6cyl springs on a bb would be spongy... Using the right springs for the engine is recommended, if you want a drop you springs designed for that engine and desired drop.. Ie.. BB springs W/2inch drop... EarlyClassic can setup you up with just about any stance you want.. and do it right so you get good handling..
`72 Cheyenne Super LWB, 402/TH400, Coils in rear, Med Olive cab over Dark Olive Body and Wood insert trim..
Currenly being stripped down for a Frame Off fixer upper...
Snyk is offline   Reply With Quote
Old 10-26-2001, 08:48 AM   #3
BW71
Post
I got a question along the same lines, can I put a 3/4 ton front spring up front on my 71 1/2 ton. I'd think it would work like stllookn said. The guy at the parts store didn't think the springs would fit between the a arms on a 1/2 ton. But the parts are the same on 1/2 -3/4 ton right? or am I wrong.
71 C-10 custom Deluxe
Leavenworth, Kansas
BW71 is offline   Reply With Quote
Old 10-26-2001, 11:10 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
stllookn,
The springs should be interchangeble. The only difference is the BB and SB versions. If you plan on putting a BB in a 1/2 ton I would opt for the BB springs. The front end will be stiffer and sit higher until the BB is installed.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-26-2001, 12:46 PM   #5
stllookn
stllookn's Avatar
Post
Thanks guys, that is what I thought. I just need a cheap fix for the leaning truck at the moment...will do the 3" spindles later to lower it right and will have good springs to boot.
Old 10-27-2001, 11:07 AM   #6
BW71
Post
This might sound stupid but I just need some clarification. As I understand it heavy duty 1/2 ton springs are BB springs for trucks so equipped with a BB? 3/4 ton springs are the same height but stiffer for the punishment that a 3/4 ton would see. So my real question is that will heavy duty half ton springs give me a lift up front since I only have a small block or will it be stock height? Just wondering I'd like about an inch or two of lift on my half ton 2wd. Thanks in advance.
Leavenworth, Kansas
Old 10-27-2001, 07:58 PM   #7
slam33
slam33's Avatar
Post
1/2 ton BB springs will lift it almost 2 inches but your going to be a bit stiff. 3/4 SB and BB srings are the same as 1/2 BB springs. Then they have a BB HD spring too but you don't want that. I've gone with the BB 1/2 ton springs and there going in as soon as I get the rest of the front end gathered up. If it's too stiff I'll make a 100lb skidd plate that should just about load the spring without any drop.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 10-28-2001, 01:49 AM   #8
BW71
Post
Thanks slamm33 for the info. I've got the HD 1/2 ton spings that i'm gonna install. It's just the time and patience that I need. I've got new balljoints too but just working on the rear suspension for now. I just was looking for an idea of how it would stand when done. I'm looking for a stiffer ride anyway.
Leavenworth, Kansas
