10-27-2001, 03:23 PM | #1 |
Smashed finger, tips on rear coil removal
I'm attempting to replace my rear coils, until I smashed my finger. Hers the problem, I got the lower bolts and cups off but I cant seem to get the upper bolt to break loose. Its been soaked in liquid wrench for a couple of days but wont come loose, therefore cheater bar plus 30 years durt and rust=big pain in the a$$. any tips?
71 C-10 custom Deluxe Leavenworth, Kansas |
10-27-2001, 04:46 PM | #2 |
Also is the upper nut in the frame rail tack welded in place or do I need to put a wrench on it to hold it in place?
10-27-2001, 08:01 PM | #3 |
I think I had to hold the top of the bolt when I did mine. You might want to try some heat on the nut while your at it.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
10-27-2001, 08:29 PM | #4 |
Yes, you have to hold the nut. I have to slide a pipe over my ratchet to break the bolt loose.
------------------ Randy70C-10 WWW.Randysrods.freeservers.com 1970 Chevy C-10 shortstep 30 Ford Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast! 87 Harley Sportster(couldnt get a 350 to fit) Self Propelled Lawn Mower Built in USA!!!! |
10-28-2001, 01:39 AM | #5 |
Thanks guys. I'll attempt it tommorow and hopefully it will work.
10-28-2001, 09:04 PM | #6 |
Heated both those bolts up real good put on the breaker bar with a 5 foot cheater and the bolts just sheared right off. The spring cups were rusted to the frame nothing a cold chisel couldnt take care of. I was able to squeeze the old springs by hand about half inch. That shouldn't be right.
10-28-2001, 11:08 PM | #7 |
Strongman Garage
either your superman or those are some WORN SPRINGS
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
10-30-2001, 04:48 PM | #8 |
Yeah, they were some really worn springs. compared them to the new ones and the new ones dont even budge. the aux leaf springa would slam down on the rear of the control arms every time I went over a bump. Hopefully not any more, I put in some 3/4 ton springs back there. Next is the front end any body have any tips on doing that. I;m gonna do everything up there, springs,balljoints,control arm shafts, tie rod ends...
10-31-2001, 01:06 AM | #9 |
heres a tip for ya, i drilled a hole the size of my extension through the frame above the nut, (gotta have the bed off) then put socket on nut, run extension through hole and connect, made life a lot easier.
------------------ 68 swb fleet soon to be bagged and big block powered 68 lwb fleet in primer 35 chevy truck 97 dodge on 35 boggers 3 out of 4 aint bad! Jefferson city, MO |
10-31-2001, 10:37 AM | #10 |
Thats a good idea. But I didn't have the bed off. Wish I did though, could have cleaned and painted some stuff. Another question, Are there supposed to be pads between the frame and bed on a steel bed? Mine are missing. Trying to get rid of rattles and clicks.
10-31-2001, 01:42 PM | #11 |
Having gone thru all of the afore mentioned trials and tribulations I found that best prices (and availability) for replacements for rusted out parts, like spring cups, U-bolts, and all proper fasteners, etc. is, believe it or not LMC!!
------------------ 72 swb cheyenne super 350/350 69 cst20 BB longhorn
72 swb cheyenne super 350/350 69 cst20 BB longhorn Warren, OR |
10-31-2001, 06:02 PM | #12 |
Rustfree.. I believe you are right about the LMC prices. I'd been looking for a kit to do the suspension front and rear and LMC had the lowest price and they are about an hours drive from me. Chevy duty has the same kit but about $150 more. They are close to me too.(free shipping,I get to go pick it up)I figure most suppliers get their parts from the same place so you just need to find the best prices. Except a U bolt I got from LMC in the kit was crooked. No big deal.
------------------ 71 C-10 custom Deluxe
10-31-2001, 07:12 PM | #13 |
I beg to differ with you but we sell MOOG suspension parts only and our in house U-BOLTS are 3/4" dia. with 1" nuts and rolled threads not cut threads,our leaf springs are made to better than G.M factory specs, our a-arms and spring cups are G.M.OEM parts and all our suspension bolts are correct grade 5, our coils are progressive rate and have a lifetime warrantee, all brake parts are wagner. Maybe a little higher in price but who wants junk suspension parts they have to replace in 5 years. Don't risk your life to save a few bucks.These are the parts we use in our customers restoriations and believe me they ride and stop like new trucks.
------------------ www.mothertruckers.net
Rest in Peace Ed. Thanks for all the good times. |
10-31-2001, 11:01 PM | #14 |
MOTHERTRUCKERS..I see your point. I should have looked into your kits but didn't know your store was around. Checked out your site though.
11-01-2001, 01:47 PM | #15 |
If I had found this site 4 years ago when I started my 72 swb rodification I could have save money, got better parts and probably finished in half the time. Oh well..it was fun anyway!! And I still have the Longhorn to do
