The LuvShack Garage
GOT THE GLASS OUT, GOT THE T-HANDLE HARDWARE OUT, NOW HOW
DO YOU GET THE HANDLE OUT, AND HOW DO YOU REMOVE THE HATCH ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
[QUOTE= HOW DO YOU REMOVE THE HATCH[/QUOTE]
You mean from the top itself? There's two sets of 3 bolts under a small metal cover on the under side/rear of the top. |
#3 | |
The LuvShack Garage
SAME THING TO REMOVE THEM FROM THE HATCH ![]() AND WHAT ABOUT THE DAMN T-HANDLE ![]()
#4 | |
T-handle: Doesn't it just have two screws from the outside holding it on? |
#5 | |
The LuvShack Garage
TO IS LARGER THAN THE OUTER HOLE, I THINK IT'S 2 PEICE, NO IDEA ![]()
square shaft
If I remeber right my stock one removed very easily. The square shaft is the only thing really sticking towards interior. The thing it runs through I think stays in door. Maybe post a picture to jog our memory.
Bob |
#7 | |
The LuvShack Garage
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Reomove the hatch hinge access covers 1st.
![]() Remove the 3 bolts on each side,either the top side or the hatch side,whatever you prefer. ![]() reomove the screws you can see on the outside of the T-handle. ![]() Take off T-handle access cover and check the internals for clips or pin's that may be preventing removale of the handle. ![]() I have cotter pin's in mine which need to be removed before the T-handle will come out. ![]() I also added cotter pins to the rods that go out to the latches at the side.This prevents them from accidently becoming disconnected from the T-handle assembly inableing me to open the hatch. ![]() Then of course remove the suppot arms and lift that heavy hatch off the top! ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
The LuvShack Garage
![]() ![]() PIC #4 IS MY PROBLEM, MINE WAS MISSING THAT SPLIT RING ![]()
without that spring clip the sleeve the T-handle slides into will come out.
If that happens the springs will unload.
#11 | |
The LuvShack Garage
![]() Join Date: Jan 2000
I have the same problem but the T-handle is rusted to the spring. How do you remove it?
#13 |
soak it with WD40 or some other kind of penatrating oil.Give it a few taps with the handle of a screw driver while trying to pull it out.
If it's REALLY rusted it may take a few applications of WD40 to get it loose. I wouldn't recommend prying on it as you may bust something!
#14 |
Hey, this has turned into an FAQ thread.
![]() Steven B, some sort of penetrating spray should work. PB blaster always works really good for me. Any luck yet LUV? |
#15 |
![]() Join Date: Dec 2002
If the Handle is really seized and won't come free. I have removed several from the yards by lightly sanding the shaft Then take a small c- clamp and put one end on the shaft and the other one the inner bracket, No real stress on the fiberglass. Iwill break it free without bangin
