Old 01-10-2005, 08:16 PM   #1
chevybill
chevybill's Avatar
Question Front suspension torque specs?
hey guys, i want to reassemble my front suspension this weekend and was wondering could anybody point the way for torque specs for the upper and lower balljoints, inner and outter tie rods and idler arm. it is a 70 2wd with manual steering.
really want to do this the correct way if at all possible.
thanks for your help.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 01-11-2005, 09:41 PM   #2
Rod
upper ball joint nut 50 ft lbs
lower ball joint nut 90 ft lbs
tie rod ball joint nut 30 ft lbs
tie rod clamp bolts 132 inch lbs
idler arm mounting bolts 30 ft lbs
idler arm to relay rod nut 60 ft lbs
pitman arm to relay rod nut 60 ft lbs
all from a 71 c10 spec sheet ...should be same as 70
I dont visit this section too often
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-30-2019, 09:03 PM   #3
71Abby
Where did you find a spec sheet for a 71?
71Abby is offline   Reply With Quote
