Transmission Crossmember
I am trying to determine which type of crossmember I have. I thought I have a manual trans crossmember since the column on the truck was a 3 on the tree but when looking at some that are for sale on the parts board, mine looks like the auto crossmember. How can I tell the difference between the two?
Brian Thompson 99 2500 Silverado 6.0 05 Suburban (Wife's) 67 Mustang (Wife's) |
Watch out for your cornhole !
![]() Join Date: Jun 2003
If it has 2 holes right next to each other in the middle of it, it's an automatic.
If it has two holes much further apart in the middle it a standard.
Fabricate till you "puke"
67-72 trucks didnt have a trans crossmember for the stick shift trucks, the crossmember was at the bellhousing. you can however run the auto crossmember under a 3 spd stick(Saginaw.....that covers the 4 spd saginaw , & the M 20/21/22 Muncie 4 spds also). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
