Old 01-11-2005, 07:38 PM   #1
rage'nrat638
rage'nrat638's Avatar
pictures of quadrajet pull off vacuum w/devorced choke
ok guy's i am ..doing a cam change and reinstalling a stock intake and quadrajet carb....i am thinking i need a TVS...temp.vacuum switch to release the pull off to let the rear open up.....after the engine is warm....
can someone post some pictures of how the set-up would be on a 69...
or would be for the carb...i have....
see my picture.....thanks mark...
hey how's that carb. look...just rebuilt it.....
rage'nrat638 is offline   Reply With Quote
Old 01-11-2005, 08:39 PM   #2
jhow66
jhow66's Avatar
It will open without a TVS as the vacuum will drop when you go to wide open throttle.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-12-2005, 12:20 AM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I've got the same carb on mine, both back barrels kick open when you floor it. The carb I have is from a '76 2wd Blazer. Hey Mark your parts are going out tomorrow priority mail, you should get 'em Saturday.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 01-12-2005, 10:22 PM   #4
rage'nrat638
Thanks My Brother.....i Am Ready.....
Old 01-13-2005, 08:58 AM   #5
4x4Poet
I don't have a carb answer. I just wanted to complement you on the intake's finish. Looks all shiny and colorful. POR15 engine enamel?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-13-2005, 11:22 AM   #6
JimKshortstep4x4
Smile
The choke setup keeps the back two barrels from opening until the choke is warmed up. If you look, the small black bracket has a notch in it in that keeps the back two barrels from opening. Once the choke is open the small bracket moves forward to clear the pin on the shaft for the back two barrels.
Nice job on the carb and manifold!
Jim
