01-11-2005, 08:48 PM | #1 |
love my truck
U bolts how tight
Question1- I just instaled new U bolts on rear en how tight should it be?
Question2- bottom of nut is flush with end of u bolt is that ok? |
01-11-2005, 08:51 PM | #2 |
its all about the +6 inches
#1 While i am sure there is an actual torque reading, If you have a quality 1/2 inch drive impact, that should be enough. Some lock tight is a good idea too.
#2, that is the minimum that you would want...but it is perfectly fine. |
01-11-2005, 08:56 PM | #3 |
love my truck
ty andy you da man
01-11-2005, 09:30 PM | #4 |
1971 C20 Custom Camper
I think it was somewhere around 110 ft-lbs on the ones I used on the 65 last summer. It'll be close to that, give or take 10 ft-lbs.
'71 Chevy C20 Custom Camper, 454, TH400 '97 GMC K1500 5.7L |
01-11-2005, 09:47 PM | #5 |
5/8'' u-bolts ---150lbs, 9/16'' bolts 110lbs. I did a small block lift on my 4x tow truck in the rear. The guy that bent the bolts for me told me 180. But the bolts were 14'' long.
01-11-2005, 10:51 PM | #6 |
Crank on them with a breaker bar. You ain't going to break them and you ain't going to over tighten them by hand either. Pound on the u-bolt as you tighten them down.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
01-12-2005, 12:55 AM | #7 |
after you drive it for a while.retighten the u-bolts because they will strech a little.I drive the truck for 100-150 miles and retighten them.
01-12-2005, 02:00 AM | #8 |
I have a 4x4 so they take more of a beating but I tightened mine every few months after I put the rear end in. The factory service manual has the spec in the back.
'70 K-20 San Diego, CA |
01-12-2005, 02:21 AM | #9 |
As my grampa used to say "tighten til it wont budge then go a half a turn"
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
