Old 01-11-2005, 11:31 PM   #1
70c10
67-72 Addict!
70c10's Avatar
What's the difference between a 70' and a 71' column?
I need a new chrome gear shifter for my dads 70' but I think his column was taken from a 71' truck because of the pointer on it. How can you tell the differences in columns?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-11-2005, 11:50 PM   #2
Gee_Emm
The difference is the shift indicator housing, 69-70 used metal 71-72 used plastic, also the pointers for the indicators were different but the mounting holes are the same.
The shifter arms are different too but I am not sure what the difference is
Gee_Emm is offline   Reply With Quote
Old 01-11-2005, 11:51 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yup, the indicator and the pointer are all that's different. And the parts will swap one for the other.
Old 01-12-2005, 12:47 AM   #4
Rod
Looks best if you swap the indicator and the pointer from the same era.
67-70 or 71-72.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-12-2005, 08:54 AM   #5
70c10
67-72 Addict!
70c10's Avatar
The housing and pointer are plastic so I'm thinking it must be a 71'. I guess I'll buy a 71' gear shifter then. I just hate to buy the wrong part and have to send it back. Thanks guys.
Jim
