Old 01-12-2005, 01:45 AM   #1
67chevy3/4ton
using a 2x4 frame for a 4x4
I need info on a frame swap.What all would be involved to use a swb 2x4 frame and swap all the lwb 4x4 drive train and suspension over to it? Wpould I be better off just cutting the lwb frame? I've built several 2x4's but the 4x4 stuff is all new to me.Any info would be a great help. thanks
67chevy3/4ton is offline   Reply With Quote
Old 01-12-2005, 03:13 AM   #2
454_72_4X4
454_72_4X4's Avatar
My dad has did this swap a couple of times but I wasn't around to see what all it involved. I think some of the holes are there but for things like where the mount for the rear shackle of the front spring go through the frame you'll have to dig out the torch, (or whatever you use to cut something like that).
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-12-2005, 10:15 AM   #3
griesel72
griesel72's Avatar
The problem with this is that you will kill the resale value if you cut the frame, i think it would be better tring to swap the suspension, but the best would be to find a swb 4X4 frame and running gear (yeah right ) to swap your body over to.
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 01-12-2005, 09:36 PM   #4
So dimension-wise frame are the same?
Old 01-12-2005, 10:40 PM   #5
Rod
You have leaf spring rear..if not your into problems..but someone did a coil sprung rear and a front leaf on this board.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-13-2005, 02:23 AM   #6
67chevy3/4ton
I have a complete 4x4 lwb and I am wanting to convert to swb.Are the holes already in all the frames to bolt the leaf springs hangers to?
Old 01-13-2005, 10:57 AM   #7
Rod
They should be...its 4x4 already. You should just look at cutting the frame and getting it back together. efabman has pics in his posts and a dvd video with the frame cutting in it.
Old 01-13-2005, 05:42 PM   #8
vtblazer
vtblazer's Avatar
You can compare the two frames here.
http://www.chuckschevytruckpages.com/framespecs.html
I looked into the conversion briefly but was told/informed that a 2wd frame didn't have the strength.
Don't know for sure but that seemed to be the concenses.
Do a search for a swb 4x4 frame, ya never know, you might come across one.
Good luck.
vtblazer is offline   Reply With Quote
Old 01-13-2005, 07:05 PM   #9
mkmiller1
mkmiller1's Avatar
Welcome to the board! I'm located in SW Arkansas. I've got some details on doing this if I can dig them up. I've got a few blazer frames(4wd) that I've thought of using the parts from and converting a 2wd myself.
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 01-13-2005, 11:06 PM   #10
What would be different strength-wise?
Old 01-13-2005, 11:31 PM   #11
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i'm thinking of doing the same conversion as mkmiller. taking the 4wd parts off a blazer and putting on a truck and the trucks 2wd parts and putting on the blazer. any assistance is appreciated
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 01-14-2005, 12:01 AM   #12
muddyole 69
conversion
I have done the blazer/2wd to shorty 4x4 truck and it was simple just measured the distance between the original short frame cab mounts split it in two and cut out the appropriate amount of frame back from the front tub mounts on the blazer frame to make the new 4x4 frame the correct length and welded it back together anyone decent with a Mig can make the weld stronger than the original frame itself grind it smooth and paint I plated the inside just for my own piece of mind though. If you go to sell the truck most states have laws requiring you to disclose any frame modifications I would anyway just to sleep better at night just my 2 cents Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 01-15-2005, 12:39 AM   #13
ABHaulR
ABHaulR's Avatar
conversion
if you have the 4wd frame and can shorten it, it is a easier way to do the conversion. i have done both the frame shorting and the 2wd frame conversion. my 72 sub was a 2wd with trailing arm suspension and now its leafs up front with trailing arms in the rear for the soft ride. either way you decide to do it you need to make alot of measurements and double check them over and over. its alot of work, a hell of alot of fun.
good luck and have fun. just remember when you think you got it ready to cut or weld, measure again. Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 01-15-2005, 03:45 PM   #14
ABHaulR,What did you do to get 10"lift on the trailing arm/coil rear?I guess an axle-under(spring-over).What else?Also,how did you handle the panhard bar?
Old 01-15-2005, 10:55 PM   #15
ABHaulR
ABHaulR's Avatar
lift
I moved the panhard bar to the u-bolt plate, so its longer and has a smoother arch. yes for now its a trailing arm over axle. when i get the time i will finish my 3 link setup. it will have coil-overs with dualrate springs for a soft ride. you know you have to keep the wife happy, honey-do's....LOL im retilling the kitchen, dinning room, and living room. putting in a builtin entertainment center/ fire place.
Dwayne
Old 01-16-2005, 05:25 AM   #16
chevy69er
I thought about doing the trailing arm over axle on my truck.How much lift did that give you and how did u do it?Thanks!
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 01-16-2005, 10:30 PM   #17
ABHaulR
ABHaulR's Avatar
swap
just by flipping the axle under the trailing arms you get about 7 inches of lift.to do it you need to get new spring perches and you have to grind them so they are at the same angle of the factory ones. i did it by leaving the stock perches in place and matching them up. you need to lenghten the rear section of your drive line. if you put in anykind of lift block you need to redo your parking brake cables. it's not to bad of a project.
Dwayne
Old 01-16-2005, 11:09 PM   #18
sixty8c10
sixty8c10's Avatar
abhaulr, did you by any chance take some pics of your axle flip?
Old 01-17-2005, 12:30 PM   #19
ABHaulR
ABHaulR's Avatar
flip
i'll have to look, there here some place, we moved and i haven't found my disk that i loaded my pics on. as soon as i do i'll post some.
Dwayne
