where is the axle code for a 66 ?
i have two 66's and need to find the axle code on them ...any help would be appriciated ...thanks dk
on the front of the tube on the passinger side i asked the same thing
how large are the letters? i have looked at both axles and wire brushed and cleaned them , are they near the pumpkin or the drum ? any other help ????? thanks in advance .dk
mine 65 was in the midder under the brake line mine
front
does your brake line run on the backside of the axle toward the rear bumper ? thanks ......dk
its under where the black rubber hose connects to the metal hose
yes mine brake line run on the backside
![]() Last edited by KSever; 01-12-2005 at 08:43 PM. |
the ratio
Needs a Big Block
pop the cover the ratio is stamped into the ring gear it should say Gm and then 11:41 or sumthin and that a 3:73 which it most likely is
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
Professional Beer Tester
If the ratio is what you're trying to find, just jack up one wheel, mark it and also mark the driveshaft, then turn the wheel two full revolutions and count the driveshaft revolutions. If the rear end happens to be positive traction then you have to turn both wheels one even revolution. The total number of driveshaft revolutions gives you the ratio; ie 3.5 turns would be a 3.50:1, etc.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
ok
thanks for all your help ...i'll look at it this weekend ....dk
