Old 01-12-2005, 06:45 PM   #1
rustyold72
rustyold72's Avatar
Cab Dolly
Any one have plans or dimentions for a dolly to put the cab on, I'd like to make one so I can move the cab around, and also have it at a comfortable working height so I can get to welding on it
IIRC there was once a post with the plans (including dimentions) for a pretty slick one made of wood, with casters for moving it around, but I can't find the thread anywhere, and the search won't let me use the word cab
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 01-12-2005, 07:23 PM   #2
1972ChevyCheyenne
What I used as a dolly to move my cab around is an old farm wagon. I think it is a 5 ton International wagon. Puts the rockers about knee height. Working on the front or back doing a lot of welding could be difficult. The best part is you can move it where ever you want and are on stuck on pavement. I even towed the wagon with the cab to the body shop. Plan to use the same thing for the box when i get the cab back. The best part is with cars/trucks weight will never be a problem. We put a Farmall H on the wagon to get it painted and the wagon was the only wheels under it. Would be great if you own land but in town it may be ackward. Hope that helps.
Jamie
1972ChevyCheyenne is offline   Reply With Quote
Old 01-12-2005, 07:27 PM   #3
Vince Putt
Hippy
You can make this as difficult as you want. A 2x10 box with a plywood top attached to a pair of furniture dollies would allow you to move the cab about. Or a larger set of wheels would raise the box up to a more comfortable level. I should have my homebuilt body rotisserie finish this weekend. That gives a lot of flexability for working on any area of the cab. I'll post some pictures and plans as soon as it becomes a reality.
Vince Putt is offline   Reply With Quote
Old 01-12-2005, 09:35 PM   #4
stea
Here is mine. My 39 cab is on it now but it should work with a 67-72 cab. 2-2x8x8, 2- 2x6x8, 4 12" sections of 4x4, casters and a bunch of lag bolts. About $50.
http://www.imagestation.com/picture/...c/fadc8206.jpg
stea is offline   Reply With Quote
Old 01-12-2005, 11:44 PM   #5
Solver
Solver's Avatar
here are the plans and pics I think you are looking for.
They were posted a year or 2 ago.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 01-12-2005, 11:48 PM   #6
David Johnson
David Johnson's Avatar
The simplest way I've found is to stake a number of 4'x4' pallets on top of one another (you can screw them together for stability), set your cab on top of them and then you can move them around with a pallet jack. You can usually pick up a used one pretty cheap, about $50. Then when you want to work on the cab, you just release the hydraulics on the pallet jack and the whole thing sets on the floor. Nice and sturdy with no wheel locks to mess with.
David Johnson is offline   Reply With Quote
Old 01-12-2005, 11:53 PM   #7
Solver
Solver's Avatar
I used those plans somewhat but made a few mods.
First I made mine a bit taller to be able to get under and work more comfortably
2cond I raised the side bars up so I could fit the legs of an engine hoist under them
I just used an extra block of wood as you can see in the corners
Also if your gonna do it right buy the steel wheels
I did the solid rubber the first time and the first time I hit a rock while rolling around it flattened the wheel
Old 01-13-2005, 12:01 AM   #8
Solver
Solver's Avatar
with the wood dolly you can bolt a couple of 2X8's across the top and use it for a box dolly also
Old 01-13-2005, 12:10 AM   #9
rustyold72
rustyold72's Avatar
That's it thanks alot Solver, and thanks to rest who gave suggestions
Old 01-13-2005, 12:40 AM   #10
spencra
This, is my BOOMSTICK!
spencra's Avatar
I had to reply to this thread so that I can keep track of it. Hope to build one of those myself. Thanks guys.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 01-13-2005, 02:44 AM   #11
greasemonkey
greasemonkey's Avatar
I made a long cab dolly so I could rock the cab back and work on the underside as well as the top and floor. Here are some pics.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 01-13-2005, 02:59 AM   #12
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I needed one that I could roll across my pasture into the barn on uneven ground so I went with 10" rubber tire casters from Harbor Freight. Mounted them on an old frame section. Total cost about $30.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-13-2005, 03:49 AM   #13
Joesjunk
Joesjunk's Avatar
Not a very good pic, but I used a frame section also. I have Harbor Freight wheels on mine too!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-13-2005, 08:49 PM   #14
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
good post gotta subscribe too. Mine's just not cutting it. Those little piece of crap wheels at Lowe's that cost 10 bucks a pop are about worthless
WRMZ71 is offline   Reply With Quote
