Old 01-12-2005, 09:54 PM   #1
Chevelle454
Chevelle454's Avatar
Brakes...
I have a soft brake pedal in my car, it has to be at least half way to the floor before the brakes start to apply. I am thinking that the master cylinder is the problem. Any suggestions? It's kinda tricky driving, especially in the winter....
-Scott
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 01-12-2005, 10:07 PM   #2
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Try burping or bleeding each wheel cylinder or caliper, starting with the back, farthest from the Master Cylinder, working your way forward to the one closest to the master cylinder. How old is the brake fluid? Contamination is brutal on brakes, and the fluid must be kept clean.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-12-2005, 10:09 PM   #3
3 on the tree
How much brake fluid is in your master cylinder? If it is lower than normal, my guess would be a leaking rear wheel cylinder. Try applying steady pressure on your brake pedal. If the pedal slowly goes to the floor, and you are not losing brake fluid, then master cylinder is the culprit.
3 on the tree is offline   Reply With Quote
Old 01-12-2005, 10:11 PM   #4
Chevelle454
I already bled the brakes, but that's as far as I got. I don't know what else I could try without throwing money at this daily driver.
1972 C10
1972 C20
Old 01-12-2005, 10:23 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Reach down with your hand and depress the pedal. If there is some movement that has little to no resistance, then adjusting the pushrod should take up the slack.
Has your master cylinder been chainged out recently?
Old 01-12-2005, 10:45 PM   #6
Chevelle454
Yeah I can slowly push it all the way to the floor if I am at a stop sign. It does not leak any fluid, I have checked the fluid level and it's full. I will look through the service records and see if one has ever been replaced. It's kinda nice to have all the records since it was new...
1972 C10
1972 C20
Old 01-12-2005, 11:05 PM   #7
Longhorn Man
if it is sinking to the floor, then you need to replace the master. I misread what you were describing.
Old 01-12-2005, 11:40 PM   #8
Chevelle454
I can't find any record of the master cylinder ever being replaced, so I guess that is what I will do. Do I have to go through and bleed all the brakes after it's installed?
1972 C10
1972 C20
Old 01-13-2005, 12:15 AM   #9
Longhorn Man
only if you want to stop.
