Old 01-12-2005, 11:08 PM   #1
nitor
Too many projects
nitor's Avatar
Brake booster rod
Does anyone know how to change the rod that goes through the firewall on a brake booster. I bought a booster for a '71. The rod has theads on the end. The one on my '70 has a loop on the end. I need to change from one to the other. Can it be done?
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 01-12-2005, 11:23 PM   #2
neonlarry
neonlarry's Avatar
I think the end of the rod should unscrew and thread onto the new booster. When you take the peice off, it does not just unscrew though, it has a locknut on it.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-12-2005, 11:27 PM   #3
krue
Designated A-hole!
krue's Avatar
Check the pic in this thread. http://67-72chevytrucks.com/vboard/s...hlight=booster The rod with loops on either end is the power booster rod. The threads are to adjust pedal play.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-13-2005, 09:15 AM   #4
nitor
Too many projects
nitor's Avatar
I'm sorry, I said the wrong rod. This is the rod I need to change, the one coming out of the booster itself.
Jim
'04 Chevrolet Astro
Old 01-13-2005, 07:21 PM   #5
nitor
Too many projects
nitor's Avatar
ttt
Jim
'04 Chevrolet Astro
Old 01-13-2005, 09:02 PM   #6
krue
Designated A-hole!
krue's Avatar
Can't help you, I never had to touch that rod.
www.daveramsey.com
Old 01-13-2005, 10:08 PM   #7
MOTHERTRUCKERS
If the rod coming out of the booster is threaded it's the wrong booster, are the firewall brackets riveted on it or just 4 studs?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-13-2005, 11:11 PM   #8
nitor
Too many projects
nitor's Avatar
The brackets are 4 studs on both boosters.
Jim
'04 Chevrolet Astro
Old 01-14-2005, 08:27 AM   #9
JimKshortstep4x4
Smile
I have never had the need to change that rod, but it looks like the rod is staked in place and is not meant to be removed out the back.
Maybe if you separated the booster it will come out that way.
I am curious as to why your your rod is threaded.
Jim
Old 01-14-2005, 09:16 AM   #10
nitor
Too many projects
nitor's Avatar
The rod in my old booster has an eyelet on it like in the picture above. The rod on the booster I bought just has a straight threaded rod. In order for the mounting bracket, one like in the picture above, to work I need the rod to be shorter, and for that eyelet to be on it. That's why I want to change it. Besides, I already bought the booster, I would like to use it. I got it off of ebay, I can't return it. If it ends up I have to buy another one, I suppose that'll be the way it has to be.
Jim
'04 Chevrolet Astro
Old 01-14-2005, 10:26 AM   #11
MOTHERTRUCKERS
NEVER OPEN A BOOSTER THEY HAVE A HEAVY SPRING IN THEM AND WILL HURT YOU. You have a 73 and newer booster and it will not work without mods to the threaded rod. measure your old eyelet rod length and get a heim joint the proper length and thread it on the stud. OR if it was on ebay as a 67-72 booster i would get in touch with the guy for a refund.
Old 01-15-2005, 12:58 AM   #12
nitor
Too many projects
nitor's Avatar
Mothertruckers, I know better than to open a brake booster. I will probably do as you suggested get another eyelet and attach it to the rod that's in the booster. Also, the person on ebay did sell the booster as a 71-72 Chevy truck brake booster. I will contact him to see if I get any satisfaction. Apparently no one knows how to remove the rod, or it can't be done without taking the booster apart. Like I said, taking the booster apart is not an option.
Jim
'04 Chevrolet Astro
