What Ratio?
What is the laymens way to tell what gear ratio I have in my 72?
take the cover off and count the gears on ring and pinon. Divide large number by small number and there ya go.
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
its all about the +6 inches
Yup, and you get to drain the 33 year old oil, and check for metal chunks floating around too.
How about the "lazymans" way-jack up one rear wheel -put trans in netural-make a mark on drive shaft-make a mark on tire-turn tire 2 times while counting the # of times the drive shaft turns--little over 3 times= 3.08, about 3 3/4 times = 3.73 and so forth.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
ooo, I like that way
Still drivin' a Rat Rod
That way don't small as bad either
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
yeah, but then you still have old oil that isn't doing it's job.
3.08 wasn't used in these trucks, it's a 3.07 |
Right 3.08 was cars-my bad.
If it is a half ton that came with a 350, it came with 3.07s. If it came with a 307 or a 6 cylinder, it came with 3.73s. Any other ratio was optional and would be listed on the glove box sticker.
Tim |
