Old 01-13-2005, 12:38 AM   #1
slammd72
slammd72's Avatar
got some parts together!!!!
finally i am seeing some progress and i am getting exited to start working on this truck. heres what ive got so far. DJM 3" dropped spindles, rotors, calipers, wheel bearings, pads, control arms, balljoints, bags, plate and cup kit, taillight fillers, and handle flip kit. all that im waiting for to get the front suspension and bags in are the new bushings. hopefully they will be here tomorrow so that i can get this party goin! also check out the junk yard control arms. i just got them back from the sandblaster so i threw some quick primer on them. i still gotta take the ball joints and bushings out of three of em and get them painted so i better get on it because the bushings will be here tomorrow.
88 shortbed crewcab
currently getting a sfbd 4 1/4"
slammd72 is offline   Reply With Quote
Old 01-13-2005, 12:47 AM   #2
slammd72
slammd72's Avatar
and only one problem...see the DUAL 1" PORTS!!!! im gonna have to open the hole in the plate for a fitting.
88 shortbed crewcab
Old 01-13-2005, 09:54 AM   #3
Ric83
Ric83's Avatar
Awesome!! Bet you are just anxious to get started.
So is your truck still a dually or has the transformation been done yet??
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 01-13-2005, 12:39 PM   #4
PHOENIX
What truck are you putting this stuff on?
What are the details on the brakes?
Are you still going to get that truck in your avatar?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-13-2005, 07:36 PM   #5
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Better paint the spindle and any other bare metal. It will rust quick!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-13-2005, 10:02 PM   #6
kevinr1970
Yeah, what happened with the truck in the avatar?
Are you putting all the parts on the 88 CC in your sig?
If so, you are converting from 1T to 1/2T?
Will bags still give you the load capacity (1 ton) as the spring set-up?
I like the idea of what your doing, CC SWB, and was wondering if you wouldn't get a better ride with 1/2 ton suspension. Do the bags give you a better ride than the springs?
Hope it all works out!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-14-2005, 12:42 AM   #7
slammd72
slammd72's Avatar
ok heres the deal. the truck in my avatar is what i hope mine to look like only white. all of these parts are going on my black 88 cc dually. it is exactly like i got it ALL STOCK!! the only reason im going with 1/2 ton suspension is so that i #1 will have lots more wheel options and #2 the rearend i have is a shortened 9" with the 5 on 5 patern. as far as the 1/2 ton holding up to the truck, i dont think it will be a problem. because the bags are 3600#ers. i think the only thing that may be an issue is the ball joints. ill keep posting as i get this going. my truck is below
88 shortbed crewcab
Old 01-14-2005, 12:48 AM   #8
slammd72
slammd72's Avatar
maybe i am just cluless, but i had not thought of painting them. thanks for the tip. i dont know what i was thinking.
88 shortbed crewcab
Old 01-14-2005, 10:56 AM   #9
MSL
MSL's Avatar
Looks awesome its always fun to get new parts it always makes you have a feeling to work more on what you usally procrastinate.
MSL is offline   Reply With Quote
Old 01-15-2005, 10:06 AM   #10
rolnlow
rolnlow's Avatar
couldnt you just throw a 1/2 ton crossmember under the front?
www.krazykustumzkc.com
rolnlow is offline   Reply With Quote
Old 01-15-2005, 12:09 PM   #11
SCOTI
SCOTI's Avatar
On the earlier 67-72's I"ve heard that dually, 1 ton, 3/4 ton frames are taller vs. the 1/2 ton frames. Is this different w/the 73-87's? Or maybe it was just the 73-87's that were taller??? I know I heard something along those lines.
Anyone know for sure?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2005, 06:24 PM   #12
slammd72
slammd72's Avatar
i dont think that there is a difference in the crossmembers. other than the little "nipple" that recieves the divet (sp) on the lower control arm mount
i know on my dually the frame is a lot taller than on the 77 3/4 ton i had
88 shortbed crewcab
