Old 01-13-2005, 09:11 AM   #1
BowTie Billy
Drum to Disc Swap
I am looking for the necessary parts to convert my 1970 K20 Front Drums to Disc Brakes. Does anyone have the 71 or newer parts necessary and possibly some technical help? I still could use some drums if there are any out there.
-Thanks
BowTie Billy is offline   Reply With Quote
Old 01-13-2005, 09:28 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You'll spend just as much on the drums than swapping to disc. just need the steering knuckle and out w/ disc backing plates and hoses for a 71. of course rotors and the disc. I bought 3/4 ton disc for $22 each and a loaded caliper pair for $55 from autozone. Ball joints will be needed also. check your local trading post for GM front axles for sell, should be able to pick one up for under $150. if it has the same ratio as your rear swap the whole axle, if not swap the outers only. Need a dana 44 though no 10 bolt stuff, unless you swap the whole axle.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
