Old 02-12-2002, 07:55 PM   #1
chevy68388
king $h!t
chevy68388's Avatar
Post how high is to high
ok i want to lift my truck more right now i only have 3 inchs but i can stuff 35s with no probulm but they have this look to them like there is mre tire for the wheel well i want to go witha 6 inch lift its only 326 but i could go ahead and get a 8 for 382 will my tires look to small with 8 inchs of lif or is there more things i will have to do i heard u have to change the sterring arm but im not sure
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s
chevy68388 is offline   Reply With Quote
Old 02-12-2002, 08:20 PM   #2
'72 Cheyenne Super
Post
Best way to start is to check with your local state patrol inspection station, to see what the bumper height laws are. Then, if you can do a 6" with 35's, go for it! A buddy of mine had a '69 with a 4" and 35's, and it looked like it could use a bit more lift. But, it ain't worth spending the money and doing all the work if you're going to run afoul of the local gendarmes!
Oh, and yes, 4 or more inches of lift, and you should change the steering arm.
[This message has been edited by '72 Cheyenne Super (edited February 12, 2002).]
'72 Cheyenne Super 4x4, 468ci, 700R4, Import Stomper.
A couple pics at http://www.picturetrail.com/gallery/view?p=6&uid=529895&
'72 Cheyenne Super is offline   Reply With Quote
Old 02-13-2002, 04:36 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
id go with the 6" lift..
remember the higher you go the more added cost of certain things... like brake lines, steering etc
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-13-2002, 08:50 PM   #4
chevy68388
king $h!t
chevy68388's Avatar
Post
see thats the thing i dont have to buy them they both come with brake lines a the 6inch said i could use my factor sterring arm if i wanted but for the 8 i have to get a new one
Old 02-17-2002, 09:40 PM   #5
71BBK10
Teufelhunden
71BBK10's Avatar
Post
something that kinda scares me(on my truck at least) my drag link ends are totally fubared, i eventually want to lift mine 8 inches and a dropped drag link would not be a bad idea, not sure if yours are okay but it seems like a worthy investment to me..
1971 K10 lwb fleetside 402 T350 205
71BBK10 is offline   Reply With Quote
Old 02-17-2002, 10:36 PM   #6
chevy68388
king $h!t
chevy68388's Avatar
Post
yea i was thinking about all that stuff im going to go and get this lift system that has the drag link and brake lines and some other stuff the only bad thing is its a block lift and not a spring
Old 02-21-2002, 07:39 PM   #7
GMC_Legacy
Post
do some math and see about your driveshaft lengths and angles. make sure you driveshafts will be long enough with both lifts. lengthing can get expensive. i have seen front driveshafts hold up to the angle of a 6" lift, 8" may be pushing the capability of the CV/U-joint.
GMC_Legacy is offline   Reply With Quote
Old 02-22-2002, 02:07 PM   #8
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
You need the steering arm with even a 4 inch lift. And with a 6 inch lift I have seen Lots of u-joints go bad because of pinion angles, make sure you get that fixed.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
