Old 01-13-2005, 08:56 PM   #1
bagged91
Out draggin'
bagged91's Avatar
Can anyone identify these parts????
Below are pictures of an underdash steering column mount and an intermediate shaft from the same column. The column is an automatic tilt... Are these van parts? Motorhome?
The steering column mount has the letters "MNP" stamped into it. It has the same bolt pattern as the stock flat plate that goes under the column and it also has the holes in the same spot for the pedal bumpers...
ANY HELP WOULD BE APPRECIATED...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 01-13-2005, 09:06 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Looks like van stuff to me. The intermediate shaft is way too short for a truck one.
Old 01-13-2005, 09:14 PM   #3
MOTHERTRUCKERS
Id put my money on a motor home column and drop mount because the column shaft is short like a trucks.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-13-2005, 09:31 PM   #4
bagged91
Out draggin'
bagged91's Avatar
OK... That's what I thought. Thanks guys....
92 GMC K1500 Burb
Old 01-13-2005, 09:43 PM   #5
Bob Moore
Without the intermediate shaft(which it looks like you already took off) that col. should be the same length as a true truck tilt col. If it is an early tilt, the PRNDLL should also have early style lettering rather than the later(more common) van lettering style.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-13-2005, 10:15 PM   #6
teamharvey
teamharvey's Avatar
I have to go with motor home as well ( although I have never seen one ) just for the reason the inter. shaft you have pictured is much smaller than a van or truck one, and the bracket is different as well.
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 01-13-2005, 10:41 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Looks just like the one I pulled from a 1 ton van.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-14-2005, 04:54 PM   #8
bagged91
Out draggin'
bagged91's Avatar
Anyone have a pic of what the differences in the PRNDLL script are?
Thanks!
Joe
92 GMC K1500 Burb
Old 01-14-2005, 05:45 PM   #9
Bob Moore
Prndll
I'll e-mail a picture tonight of both styles. Maybe you could then post it for others.
Thanks - Bob
vac, 454, T400
more to follow
