Old 02-17-2002, 04:51 PM   #1
johnymac
Question Best way to remove rivets from frame?
I need to remove 6 rivets from my frame in order to install my new shock relocator kit and a front sway bar on my 67 C10.
I am curious what methods have been used in removing these rivets?
I hear drill them out, or use a cutting wheel on a drill, grind them off, not sure which might be the easiest.
I am going to try and tackle soon, my power tool collection is shall we say lacking.
I have a friend with a portable air compressor, I was thinking maybe buying an air drill.
Can anyone suggest the best way to remove these before I start buying any tools.
Thanks very much!!
johnymac is offline   Reply With Quote
Old 02-17-2002, 05:07 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
use a 4 1/2 grinder to grind the heads down, and if they dont come out after that drill them out (ALOT easier to drill them out after you grind the heads down)
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-17-2002, 06:40 PM   #3
u2slow
Web Wheeler
u2slow's Avatar
Post
You can use a torch if you're good... or grind them down, then assault them with an air hammer. Both ways work good
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 02-18-2002, 03:20 PM   #4
upzndownz
Post
best way I've found is to grind them flat then drill them out
71lwb C-10 rust-free ac 300crate,2004r,4.10 lowered2/3,some original black/white paint 50%primer DAILY DRIVER
71 2wd blazer leaks EVERYWHERE rusty starts and drives everytime,DAILY DRIVE
LOOKING FOR 38-39FORD coupe
upzndownz is offline   Reply With Quote
Old 02-18-2002, 07:47 PM   #5
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Talking
Quickest way is to get a sharp metal chisel, a big ball peen hammer, and a pair of heavy leather gloves (you will smack your hand at least once!) And place the chisel right up next to the frame rail at the edge of the rivets. Give it a good sharp rap, and you will be surprised how easy they cut off! You also will need a 1/4 to 3/8 inch drift pin to knock out the rivets. It is clean; plus you won't end up with any grinder marks or whoops! holes from the torch!
BEEN THERE, DONE THIS, AND IT WORKS! ricobob
If you think you can you're right. If you think you can't you're still right.
Current project: 1957 Chevy Short Wheel Base Stepside, with '58 GMC Big Window Cab, w/327 camel heads, 350 TH Automatic, tilt wheel, and thinking of doing a IFS.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 02-19-2002, 07:04 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
I agree with rico_bob. I used the same method on my truck when I lowered it. One good whack and the rivet heads come right off!!! Easier than the other methods mentioned.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-19-2002, 11:40 AM   #7
ColinOpseth
Post
the same concept works for when you lose the wheel locks on your car (minus the drift pin (punch) step)
i agree with the previous two posters, knock the head off the rivet and then punch out the rivet
Webmaster: www.GMPerformance.org
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 02-19-2002, 12:02 PM   #8
johnymac
Post
I want to thank everyone for the ideas.
I am going to buy the chisel and punch tonight. If that fails, will buy the grinder this weekend.
Really appreciate the info!
Old 02-21-2002, 04:36 PM   #9
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Post
have fun grinding
imaindianoutlaw@yahoo.com
REFRIGERATION TECH
FOR SALE
1963 Pontiac Tempest
1965 Pontiac GTO
1956 Pontiac 2 dr
Charles W. Hein
S.Williamsport PA
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 02-22-2002, 03:20 PM   #10
rustfree
Post
hope I'm not to late with this, but for what it's worth...spent a couple hours under my truck last night removing the stock upper shock brackets and if you find as little room under there as I did laying on your back trying to swing a hammer/chisel or run a grinder then I think you'll find the easiest method to removed the rivets is to center punch them and work your way up with drill bits until you can punch out the rivet shank. It worked for me anyway.
72 swb cheyenne super 350/350
69 cst20 BB longhorn
Warren, OR
rustfree is offline   Reply With Quote
