Old 01-14-2005, 12:36 AM   #1
doc_rock
doc_rock's Avatar
Wiper motor rust....
Anybody ever have the entire mounting metal around the wiper motor rust out? Is there a replacement panel for this, or am I pretty much on my own, either rebuild or buy new? I've not started taking it apart to find out what's REALLY involved in it, but it looks to be not fun.
1969 Chevrolet C-10 Bananamobile. Yes, it's ugly, yes, it's rusty, it's slow too, but no, I'm not trying to show it.
doc_rock is offline   Reply With Quote
Old 01-14-2005, 07:44 AM   #2
Sweet72
Sweet72's Avatar
You have two options since there are no patch panels. New cab or cut a section from a donor cab and weld it in as long as the rest of the cowl area isn't that bad.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-14-2005, 11:08 AM   #3
MOTHERTRUCKERS
It's a fairly common problem i guess because we have shipped over 30 of these sections in the last couple of years.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-14-2005, 03:39 PM   #4
doc_rock
doc_rock's Avatar
the upper part of the cab where the heater bolts in is rusted out, nearly gone...the floor of the cab's got rust (I could floorpan it, but it sounds like I need a new cab and be done with it)
