01-14-2005, 06:37 PM | #1 |
It followed me home?
sprung spring?
Can anyone tell me what it means when a leaf spring has been sprung? and does it affect the integrity of the spring? something to do with the leaf being overtorqued/overloaded?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-14-2005 at 06:41 PM. |
01-14-2005, 07:29 PM | #2 |
Sounds like a bent spring to me, usually they end up shaped like an "S" because if you run blocks it likes to twist on the springs causing them to become mis-shapin and wear out, or they have been bent from being hit on something or flexed too far.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
01-14-2005, 09:29 PM | #3 |
user # 2756
I always thought of fatigued springs as being sprung, loosing lift height or sagging. Or like a coil spring being pulled straight.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
