Old 01-14-2005, 11:52 PM   #1
gearshift
tko 600 transmission
i've got a 1968 chevy 1/2 ton truck with a 1986 350 engine. im going to put a tko 600 5 speed trans in. it has a 3 speed now. does anybody have pics on this. like where can i put the hyd clutch. and can i still use the 68 bellhousing. any help will be helpful. thanks
gearshift is offline   Reply With Quote
Old 01-15-2005, 12:48 AM   #2
Willy Prost
Correct me if I'm wrong, but the TKO600 can use your existing bellhousing and clutch linkage. You need a 26spline clutch disk (mid 80's camaro wiith T-5 will do). I felt that a high hump tranny cover helped keep clearinces in check. A shorter driveshaft was needed. I recomend a mid mount shifter from Hanlon motorsports
http://www.hanlonmotorsports.com/
This will clear the bench seat in your truck.
Willy Prost is offline   Reply With Quote
