Old 01-15-2005, 12:20 AM   #1
low 84
low 84's Avatar
new tach dash question
i searched the old tach threads and read crossys write up but this isn't covered.
i'm pretty sure the answer is no, but i was wondering if the gage cluster housings between a tach dash and non tach dash are interchangable. on the tach dash i just got a couple of the mounting points that mount the cluster housing into the dash are broke off so i'd like the swap the tach and guages to a different housing if it would work?
if not i can make the one i have work but it would be nicer to swap them
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-15-2005, 09:59 AM   #2
Jonboy
Slots go on anything!
there is a cutout in the carrier where the tach goes. If you are able to get that cut out, it may work.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-15-2005, 11:40 AM   #3
Russell
Professional Grade
Russell's Avatar
I did the swap. The biggest issue was the small fuel gauge in the bottom left, I wound up running wires from the gauge's poles to the metal on the circuit board. My tach bezel was all beat up and ugly, half of the mounting holes were broken etc
I used a dremel with a cutting disk on it to cut out the holes I needed for my tach, and a drill to make the holes needed for the fuel gauge wires
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-15-2005, 08:06 PM   #4
low 84
low 84's Avatar
thanks guys!
'05 1500 Crew Cab
RIP
