01-15-2005, 07:16 PM | #1 |
Oil pressure line
Has anyone replaced the metal line and fittings running from the motor to the oil pressure gauge with a flexible line? If so what did you use? I never have liked that and I am not quite ready to step up to a new gauge panel and gauges.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
01-15-2005, 07:34 PM | #2 |
i would be afraid plastic would melt or get a hole rubbed into it....
p.m. sent.... |
01-15-2005, 07:37 PM | #3 |
Hi Mark....pm back atchya. I was thinking fuel line or small braided line with AN type fittings. But, that may not be available and I may just have to use a metal line until I go with a new gauge setup with non-mechanical gauges.
01-15-2005, 07:37 PM | #4 |
I use the autometer #4AN steel braided...its the best thing you can do
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
01-15-2005, 07:39 PM | #5 |
Watch out for your cornhole !
Pretty much all aftermarket guages come with the white plastic line. I've used it a lot without problems.
My local hose shop was able to sell me all the fittings from the block to the guage with copper tubing like original for 6 bucks though, if you want new stock type stuff.
01-15-2005, 07:41 PM | #6 |
Merciless Butcher
Here's a pic. I used -3 an braided stainless with a bulkhead through the firewall. Check out Summit. They will have everything you need. That's where I got all of the parts I used. Look at the pic close ( sorry, lots of other crap in the way.). You can see where it comes out of the block and goes to the bulkhead fitting. The other bulkhead fitting goes to the vacuum gauge. It has not leaked yet.
Your Bought And Sold....I Got Your Soul! Last edited by gonebad2; 01-15-2005 at 07:58 PM. |
01-15-2005, 07:49 PM | #7 |
Thanks for the suggestions----these are what I was looking for----plus I got $100 in gift card money sitting at Summit. Yaaayyy...
