Old 01-16-2005, 11:05 AM   #1
76bonanza
76bonanza's Avatar
blower motor question
My blower motor or fan is starting to make a rattling sound? Is it easy to replace? Like it looks just unbolt old and bolt in new? And tricks or problems with this? It does come out from the engine side right?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 01-16-2005, 11:18 AM   #2
rolson1039
it comes out of the heater box or the ac box its a couple of quarter inch screws and two wires one of which is a ground that attaches to a clip to one of them screws its real easy
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 01-16-2005, 12:31 PM   #3
76bonanza
76bonanza's Avatar
but it comes out in the engine compartment not from under the dash right?
1968 c10
lowered 3" 4"
Old 01-16-2005, 02:33 PM   #4
rolson1039
ouyt of the engine compartment mine is a non air truck its simple enough from the outside im not sure of an air truck
Old 01-16-2005, 02:37 PM   #5
cochino12
It followed me home?
cochino12's Avatar
a.c truck is in the same place, 10 min job.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-16-2005, 04:59 PM   #6
76bonanza
76bonanza's Avatar
O.K. I pulled my motor ran it outside of housing ran fine. Put it back and it starts rubing and hitting the inside someware. I used some washers to shim it it is better now but still not right. Is the motor just wore out and letting the fan wobble to much? Just dont want to replace the unit if I dont have to blows real nice even with noise.
1968 c10
lowered 3" 4"
Old 01-16-2005, 08:02 PM   #7
ozrulzk5
What can I do next ????
pull the motor out and bench test it. I have found in others that they seem to suck some trash up in the housing where the motor bolts up to. if the motor does fine on the bench test run your hand down in the motor housing and feel around. just replaced a motor myself and cost was almost 20 bucks for a new one at a local parts house
ozrulzk5 is offline   Reply With Quote
Old 01-18-2005, 05:51 PM   #8
76bonanza
76bonanza's Avatar
Anyone know if that plastic wheel pulls off once you remove the nut?
1968 c10
lowered 3" 4"
