Old 01-16-2005, 02:43 PM   #1
chevytruckfan
chevytruckfan's Avatar
Anyone install an Autometer Tach?
I got an 8000rpm Autogage by autometer tach for christmas. Since the wiring does not reach the fuse block I am going to get some more wire and a connector to plug into the HEI. My ? is where did you connect your other wires to? Where did you run the ground, 12V switched power, and 12V dash lighting?
chevytruckfan is offline   Reply With Quote
Old 01-16-2005, 02:53 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
THere is a termina on the fuse box that will turn the light on and off (and brightness too) . Look in the FAX for a labeled pic
The green wire goes to the HEI tach terminal
the black...just ground that one anywhere under the dsh. I normally use the bolt that holds the plate with the brake pedal stops. Right under the steering column.
Old 01-16-2005, 03:18 PM   #3
chevytruckfan
Ok so if I am reading it right I will connect the white wire (light source) to the panel light fuse, and the red (power) the cluster feed or the ign unfused?
Old 01-16-2005, 03:20 PM   #4
1972C10
1972C10's Avatar
Be sure that you have an inline fuse around 3 or 5 amps Since most of the fuses that control the terminals on the fuse box are 15A+ and the tach calls for a small fuse IIRC
Ive got all my Tachs wired up with a blade inline fuse holder I have my ground More than likley hooked on the same bolt as earlier stated.
The 12V And The Ilumination Wires are plugged into the fuse box And The Green One Goes To the Tach
1972C10 is offline   Reply With Quote
Old 01-16-2005, 03:20 PM   #5
1972C10
1972C10's Avatar
The Cluster Feed Is The Panel Lights.
If you use IGN Unfused Be sure To Put An Inline In.. Fuses are cheaper than tachs.
White -- Plug Into Cluster Feed
BLK -- Ground
Red 12V-- IGN Only
Green -- Tach
Old 01-16-2005, 04:29 PM   #6
Longhorn Man
Sorry, should have been a little more clear on that.
Old 01-16-2005, 05:41 PM   #7
chevytruckfan
Ok I got it out now. I went to Parts store to get fuzes and some wire. No one had any terminal connectors to plug into the hei. Once I get that part from a yard off another hei dist I should have it all connected. Thanks for the help guys you
Old 01-16-2005, 07:38 PM   #8
Longhorn Man
femail spaid connector will work fine.
If you do the junk yard route, grab the wire off an olds or a caddy where the dist is way up front. That way you can chop off 3 feet of wire, and route a single wire under the hood instead of making another connection.
