lowering my 72
I've got a 72 GMC sierra. i t was origionally my dads, and ive taken it all down to the frame and resored it (its still primer flat black though..plan is to 2 -tone it red and white with all teh original chrome) i want to lower it 4" in the front and 6" in the rear. i have leaf spring suspension in the rear and reg. coils in the front...what is the way to go about lowering it (no axle flip kits or airbags)
thanks, Kevin |
Watch out for your cornhole !
![]() Join Date: Jun 2003
A drop spindle and drop coil will do the front.
In the rear, a drop leaf spring combined with lowering shackles will do it. Early Classic has everything you need to do the job front and rear.
If you have a wood floor make sure you dont use a 2" drop shackle. it will hit the floor.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
thanks
nope, ive got the standard metal bed floor (long, fleetside)
thanks for ur guys' help |
welcome from vegas
70 blazer 350 3on tree 98 GMC 3/4 ton 4x4 5 speed manual |
