Old 01-16-2005, 10:50 PM   #1
chevybill
chevybill's Avatar
Question front lower bumpstop install?
I am in the midle of my front suspension rebuild and need some tips on installing the lower rubber triangle shaped bumpstops.
Is there a trick or any helpful hints are greatly appreciated.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 01-16-2005, 11:00 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Put them in the microwave for about 10-15 seconds then run outside and pop them in. The heat makes them pliable.
Old 01-16-2005, 11:47 PM   #3
SCOTI
SCOTI's Avatar
I tried the microwave thing & it didn't work for me. I tried boiling water as well w/no luck.
What I wound up doing was drill an access hole (I had a 5/8" hole-saw handy)in the front of the bump-stop 'mount' so that I could grab the rubber & help pull it into place while pushing/wedging it in from on top. I also used a little dish washing soap to make things a little slippery. It took longer to drill the hole than pull the snubber into place (& it didn't take long to drill the hole).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2005, 12:35 PM   #4
chevybill
chevybill's Avatar
thanks for the replies
Old 01-17-2005, 01:03 PM   #5
ChevyDude
Dish soap and alot of wiggling and forcing them into to slot.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 01-17-2005, 03:23 PM   #6
67chev
67chev's Avatar
I sprayed mine down with silicone, popped one side in, then used a flat prybar (could use a big screwdriver) and pushed the other side down into the channel. Good luck however you try to do it!!
"SicStee8" Chevy SWB Fleetside, in progress...500 HP 383 w/TriPower, 700r4, 3.73's, Lowered, Shaved Driprail/sidemarkers/handles/ant, Gonna rock!!
'96 Chevy Tahoe 4X4
'84 Chevy C/K10 4X4 (FOR SALE)
67chev is offline   Reply With Quote
Old 01-17-2005, 08:36 PM   #7
Vince M
Vince M's Avatar
I just did mine this week. I got some liquid laundry soap...gooped a bit on the triagle shape and pushed it straight down. Went in real easy. Mine were brand new so they were already pliable. My lower A-arms are also powder coated so that might have helped. They are real shinny and slick.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 01-17-2005, 11:28 PM   #8
4x4Poet
If you already have the silicone (tube or spray), it would be a little better since it's not water based, is harmless to rubber, and is more slippery.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
