Old 01-16-2005, 11:21 PM   #1
72 Cheyenne K20
F/S 70 3/4 ton 4x4
I wanted to see if there is any interest in my 70 3/4 to 4x4 my duaghter refers to as Ketchup. I have a 72 3/4 ton 4x4 that is Ochre that she calls Mustard. I hate to break up the team but can't have 2 restos going at one time. It has a 350/350 w/NP205. Motor runs smooth and tranny shift great, came with factory engine block heater that work great. I just finished putting the NP205 linkage back together and it is tight. There is a ujoint on the front axle that is shot that will be replaced on wednesday. After that the 4wd is good to go. It has P/B, P/S, new battery, water pump, dome light, and replaced tranny lines. All of the breaks were replaced 4 months ago to include brake cylinders. P/S works well. It has fairly new exhaust and mufflers. I noticed to day it has a leak at one of the connections that I will fix before it sells. It has factory A/C with all of the components intact. It blew cold this last summer but the compressor was starting to squeal so I removed the belt. The interior is all stock, needs the seat recovered and a ned drivers door panel. The bed was put on by the PO, it has very little rust, one stop near the tailgate, other than that,pretty clean with only surface rust. The door and fenders are workable, both fenders have rust in the front lower section and the doors are better than exspected with no speaker holes. The cab needs some work. Cab corners, inner/outer rockers, drivers side floor, cab supports. This truck is all original w/ no mods that I can see. Electrical all works and not hacked up. Even has the heat riser on it. Over all for a daily driver I would go anywhere with it. The first $1700.00 I get can have it. Any question let me know.
Thanks, Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 01-16-2005, 11:47 PM   #2
2low72
To Bad your not closer
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 01-17-2005, 01:36 AM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
what he said!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 01-17-2005, 02:03 AM   #4
4bynut
4bynut's Avatar
Scott, where in MN are you. I'd be interested if your not far from NW IL. Thank's Jason.
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 01-17-2005, 02:14 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
that sounds like a good deal.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-17-2005, 11:54 AM   #6
Low69CST
Do you have a picture of under the cab? Would you be interested in meeting someone half way to look at the truck?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-17-2005, 07:23 PM   #7
72 Cheyenne K20
4bynut - I live in southern Minnesota, about 1/2 an hour from Ia right off HWY 35. If you need more pics let me know. If you want it I can meet you half way.
Low69cst - I would love to able to meet half way. But I own 2 restaurants in the twin cities and can't seem to take time off for more than a day right now. I can still send pics if you want.
Thanks, Scott
Old 01-18-2005, 05:55 AM   #8
4bynut
4bynut's Avatar
Sent ya a PM.
Old 01-18-2005, 02:48 PM   #9
berghandler
Pm sent
berghandler is offline   Reply With Quote
Old 01-18-2005, 10:08 PM   #10
72 Cheyenne K20
4BYNUT & Da Burb - no rust on the outside or inside of the top of the cab. Still has drums all the way around. I'm on for 2nd shift tomorrow so I will get more pics and send them to you guys. I forgot to mention, it does have a 5000lb tow hitch installed. Da Burb, I love the ochre, my favorite factory color in these trucks. Mines a little faded but a new paint job in the near future.
Thanks, Scott
Old 01-19-2005, 01:10 PM   #11
hotrodchev
Hi Scott,
I'm interested in the 4x4 and was wondering how I could reach you to further discuss this truck? Please e-mail me at tclift2078@aol.com with your contact info. and location of truck in Minnesota.
Thanks,
Tim "Hotrodchev"
Lino Lakes, MN.
hotrodchev is offline   Reply With Quote
Old 01-19-2005, 02:35 PM   #12
72 Cheyenne K20
Hi, anyone interested can call me just about anytime (7am-11pm) on my cell @507-213-3463. If you dont get me right away, just leave a message and I'll call you back ASAP.
Thanks, Scott
Old 01-21-2005, 05:21 AM   #13
4bynut
4bynut's Avatar
Hi Scott, did you sell the truck? If not still waiting for pic's. Thank's Jason
Old 01-21-2005, 02:29 PM   #14
berghandler
Scott
Wondering if you got the PM I sent you about some pics???
Old 01-21-2005, 06:49 PM   #15
72 Cheyenne K20
Zoomy, post/send me your e-mail address and I'll get you some pics.
Scott
Old 01-21-2005, 06:56 PM   #16
teeitup
Just like to part out trucks!!
teeitup's Avatar
Man that looks like a buy, I bought one last week or I'd be thinking about a road trip. Good luck, you shouldn't need it though.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 02-07-2005, 10:43 AM   #17
hotrodchev
Ketchup has a new home.
I'm proud to say that "Ketchup" has a new home in east-central Minnesota and she's everything Scott described. My future plans will be to restore "Ketchup" back to her old glory while I keep her in operation to do minimal tasks around the yard. I will probably be in the market for some clean sheetmetal and other miscellaneous parts in the near future, so I would really appreciate it if you would drop me an e-mail and let me know if you can help.
Also, I currently have for sale a 1972 Chevy short-wide box 2wd pickup and a 1989 Chevy 1/2-ton 4x4 W/T. Trades considered. E-mail me at tclift2078@aol.com for further info.
"Hotrodchev"
1970 Chevy 3/4-ton 4x4
1972 Chevy 1/2-ton 4x4
1972 SWB 2wd pickup
1969 Chevelle SS
1968 Nova SS
1970 Nova SS
1969 Camaro "Hugger Orange"
1969 Camaro "Lemans Blue"
