Old 01-17-2005, 12:04 AM   #1
jose
jose's Avatar
WTB 68 under dash wiring harness .
The title says it all . Want to buy an unmolested/uncut 68 under dash wiring harness for automatic .
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 01-17-2005, 12:10 AM   #2
lamar
lamar's Avatar
I might have one I'll check and let you know.
72 C-10
lamar is offline   Reply With Quote
Old 01-17-2005, 12:14 AM   #3
longhorn71
longhorn71's Avatar
just a quick note.there is two harnesses for these trucks.One with gauges and one with idiot lights.plus there is two different under hood harnesses too because of this.so make sure you get the right one.just thought i would let you know.
longhorn71 is offline   Reply With Quote
Old 01-17-2005, 12:17 AM   #4
lamar
lamar's Avatar
Hey longhorn71 what is a easy way to tell the difference? That way I said I'd have to check I have a few just have to take out to my truck to know the diff.
72 C-10
Old 01-17-2005, 12:36 AM   #5
jose
jose's Avatar
Good call longhorn71 , I want the one for gauges .
68 GMC 4x4 SWB
jose6772@yahoo.com
Old 01-17-2005, 01:27 AM   #6
longhorn71
longhorn71's Avatar
here is the wiring diagrams
Old 01-17-2005, 01:29 AM   #7
Rod
Look at the plug that goes into the back of the gauge package. If the second space is blank its a full gauge..if a third space is blank its a idiot gauge. Thats a general quick look...you really have to know what your looking at overall...there are difference in plugs and wires between standard 4 speed tranny , 3 speed tranny and automatic tranny harnesses on the inside also.
The blank space is on different sides..but generally a 2nd space or 3rd space is a quick look guess between the 2 types.
Basically an auto has 2 purple wires to a plug for neutral safety switch.
3 speed has greens and yellow perhaps to reverse switch only.
4 speed has a wire to tranny.
Also 67 and 68 have harness fuse blocks that mounts sideways.
Takes a bit but I can grab and know what I have in hand.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-17-2005, 07:40 AM   #8
lamar
lamar's Avatar
Thanks that makes it much easier. jose I'll let you know this afternoon.
72 C-10
Old 01-17-2005, 12:33 PM   #9
HOTFUN
HOTFUN's Avatar
Rod
I think you meant position 2 blank or position 4 instead of 2 or 3.
Another quick method is to check if the solid black ground wire to the top of the plug in has the blank slot on the same side of the plug or the opposite. If its the same side of plug you are an idiot light and opposite sides you are loaded with gages!
Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 01-17-2005, 01:09 PM   #10
jose
jose's Avatar
Thanks Lamar let me what you come up with .
Thanks Rod and Mark it makes it more interesting . Now would i have to repalce both harnesses under my hood ? I am converting to automatic at present it has a floor shift 4 speed and gauges .
68 GMC 4x4 SWB
jose6772@yahoo.com
Old 01-17-2005, 01:26 PM   #11
HOTFUN
HOTFUN's Avatar
If I remember correctly, from the GM parts book I am sure the starter harness is different between manual and the automatic but I believe the headlight charging circuit is the same. And if it has the electric type of auto kickdown used a turbo 400 type, it would have it's own single feed wire seperate from the harness. So the kickdown is not the issue.
Mark
'72 GMC K2500 4x4
Old 01-18-2005, 05:49 PM   #12
jose
jose's Avatar
Still need the under dash wiring harness for 68 .
68 GMC 4x4 SWB
jose6772@yahoo.com
