Old 01-17-2005, 02:44 AM   #1
raphyel
Some 60 - 63 info and pics of my progress
I had bought a 62 cab to replace my 63 cab. I didnt know that the front cab mounts are in different places and That I would have to re-drill them to get my new cab to fit. Just a little info for anyone else trying to do the same thing. It was well worth the extra work as you can see.
raphyel is offline   Reply With Quote
Old 01-17-2005, 12:50 PM   #2
chevy283
chevy283's Avatar
nice
chevy283 is offline   Reply With Quote
Old 01-17-2005, 07:54 PM   #3
KSever
KSever's Avatar
Looks really nice Raphyel , I wish my cab and frame looked that nice already. Gotta wait till spring or at least till it gets warmer than it is right now -14.
Did you swap out the complete frontend on that 63 with a later model crossmember?
KSever is offline   Reply With Quote
Old 01-17-2005, 11:52 PM   #4
raphyel
No swap
I didnt swap the front end. The drop spindles and power steering setup are via GMC Pauls. I have to give it to those guys. I have had some really nice business with them. The power steering was very easy to setup. The spindles however was a challenge in that after buying them I didnt want to spend a lot on the other parts, But it can be done way cheaper than buying the whole kit.
Old 01-25-2005, 12:43 PM   #5
00droptopSS
2.5/4 on 20's
00droptopSS's Avatar
What did you have to do to get it to fit? I just had a 63 cab sand blasted and primed for my 62 SWB. I assumed they were the same.
62 C/10 SWB. Currently in ground up resto. Big back window cab, V8, auto. My wife's grandfather's truck.
1965 Mustang Vert - Shelby Clone
2005 Dodge SRT-10
My Old 72 SWB
00droptopSS is offline   Reply With Quote
Old 01-25-2005, 03:01 PM   #6
raphyel
Setup for cab.
I just cut the old cab mounts that are in the interior floor and drilled the tack welds out. I then sat the new cab on the frame and drilled up from the bottom into the interior where the new mounts are located. T then got a jigsaw and cut holes big enough to counter sink the new mount plate into the floor and after it sat flush, I tacked it in four places to hold it in. It takes a couple hours to do, but you have to do it with the cab on the frame and you have to drill from under the cab to make sure you are in the center of the hole on the cab support brackets on the frame. Otherwise you wont be able to get the cab mount bushings to fit correctly.
Old 01-26-2005, 03:35 PM   #7
apachetrucks
Very nice !!!! I have a question for you,if you dont mind. I have restored several of these cabs and all of them have the four 3/16th holes in a reversed L pattern left of the steering column opening on the firewall and I would love to know what the holes are there for.Thanks and have a great day,Apache
apachetrucks is offline   Reply With Quote
Old 01-27-2005, 12:10 AM   #8
raphyel
About those holes
I am not ceratin, But they may be for the firewall pad grommets to pin it up. I will look at mine and see if I can find anything.
Old 03-14-2005, 08:06 PM   #9
onebadcruiser
Where did you get the 62 Cab from? It is a nice one. I am trying to locate me one for my 62 stepside C10.
onebadcruiser is offline   Reply With Quote
Old 03-15-2005, 03:13 PM   #10
raphyel
Where I got cab from
I got my can off ebay. I paid 25 bucks for it from arizona. I think the guy who sold it to me maay hae another. I will see if I have his email address around somewhere.
