Old 01-17-2005, 07:46 PM   #1
60-66 Nut
Professional Beer Tester
78 C20 - 83 GMC Body Swap
Hello everybody. I'm from nextdoor at the 60-66 board, just jumped the fence to ask you guys a question. Most of my dealings have been with the older trucks, but I have had several of the 73-87 trucks, too. I have a 78 C20 with terminal cancer and I also have an 83 GMC 1/2 ton with a solid body. I'd like to put the GMC body on the 3/4 ton frame, the only thing I'm not too sure about is the front cab mounts under the radiator support. Are they different for the 83' front end? I'm pretty sure I'll have some fab work to put the 83' front bumper on the 78' frame; just wondering what else I'll run into. Thanks for any help or comments.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-17-2005, 08:40 PM   #2
Russell
Professional Grade
Russell's Avatar
I'm not sure what exact is different, but I do know that the cab mounts are different somehow. But apparantly it can be done
As far as the bumper goes -- You'll need to cut the frame to use the newer bumper. I'd just stick with the older style bumper, or find one for it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-18-2005, 09:22 AM   #3
beaterC10
The mounts on the cabs are the same, the difference is in the rubber cushion used to mount the cab to the frame. Use cab and core support mounts to match the chassis, in this case 73-80, and it will work.
The later cushions are larger OD, so the holes in the frame mounts are larger. You could use the later cushions on the earlier frame if you make the holes in the frame mounts larger.
beaterC10 is offline   Reply With Quote
Old 01-18-2005, 10:02 AM   #4
60-66 Nut
Thanks guys, much appreciated. Don't know when I'll get the time to do it, but at least I know a little more about it now. I don't think the early style bumper would look right with the later front end, so I'd rather make the right one fit. Besides, the 83' has a nice chrome bumper in good shape. Thanks again.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
