Alternative to Dynamat or brown bread
By accident I ran across this stuff at Lowes its called Peel and seal self stick alum roll roofing it comes in a 100 sq. ft roll for 79.99 36" by 33' long according to the box it comes in smaller widths. I used this weekend to do my 87 dually. works great easy to use. I didnt even use a heat gun but its pretty warm here you might have to use the heat in colder climates. I dont think I used even 1/2 the roll I may do a second layer. Just thought I would pass it along.
Steve ![]()
69 c-30 dually flat bed & dump ( best truck ive owned 87 chevy dually 97 1500 classic 89 wellcraft |
Lovin' Life in Miss.!
Thanks for the tip. Will check it out on the next trip.
The truck... you hear that? No really, you did hear that?!!! |
![]() Join Date: Aug 2001
![]() COOOOOL ... I'LL CHECK EM OUT. THANKS ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I've heard of it before. From what I've heard it works fine on a horizontal surface, but I wouldn't use it on vertical. Just a couple tips I've heard. I use Brown Bread Myself.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
I used it on the back wall of my cab and its there forever. I thought of using it on the roof I know it will stick alright but I dont know if it will affect the headliner. plus its a lot cheaper than the others.
Active Member
![]() Join Date: Feb 2000
Appreciate you passing on the tip.Its one of the best things about this board.
I'm going to try it in a daily driver type 4x4 we just started working on. Brown bread and Dynamat are pricey, especially when you're working on more than one truck. I like to find things that give a good benefit without spending a fortune.Thanks for sharing your "find" Rocky
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
Thanks, Rockguy.
I put some brown bread in a suburban. It worked well and cost a bundle! Can't wait to put some in my truck.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current) past rides were: '70 Chev 2wd farm truck '71 GMC 2wd 1/2T 402 nice! '72 Chev 2wd 1/2T 396 '72 GMC 3/4T 4x4 2500 Super Custom suburban. Bozeman, Montana |
![]() Join Date: Dec 2003
got some pics????
https://www.ebay.com/itm/295742064443 |
Im using the same stuff (peel and seal) on my 39. I found it at a local roofing supply, 12" x 33'. I've done about 1/2 the cab. If you use some 3M 90 (i think) adhesive with it it should hold to the walls and ceiling very well. I had to remove a small spot and had to use a screwdriver to scrape it off.
i just did up the entire interior of my 81 c10 with fatmat. its exactly the same as dynamat. you get it off ebay in either 50 ft or 100 sq ft. it even comes with a dynamat example to compare and a roller. it was $130 for 100 sq feet. good stuff.
67-72 Addict!
I just did this in my dads 70'. I bought this off ebay from this guy. Worked awesome!.
http://cgi.ebay.com/ebaymotors/ws/eB...=WDVW&tc=photo
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
GM ONLY BABY!!!
Anyone ever tried FAT Mat?
http://cgi.ebay.com/ebaymotors/ws/eB...category=42610
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
