Old 01-17-2005, 08:39 PM   #1
jostrans68
Jostrans68
jostrans68's Avatar
350 head ?
got everything hooked up ready to run fired right up (should have guessed problems) it appears my # 1 valve is sticking . these heads have been siiting since they came back from the shop. And of course it was a few years ago. Have any of you guys gotten a bent valve back in a set of heads? I may just buy another head dang four yrs and getting close this sucks. sounded good for the 1st 20 minutes though. any one got one good head to bolt on close to washington state? lol thanks Jack
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 01-17-2005, 09:06 PM   #2
JimKshortstep4x4
Smile
I would try running some upper cylinder lube through the carburetor unless the valve has already hit the piston. It might just be sticking and will free up.
Jim
Old 01-17-2005, 09:09 PM   #3
jostrans68
Jostrans68
jostrans68's Avatar
hasnt hit piston but I can see it stay down and its stiff enough to bend a push rod thanks
[CGTW Member
Old 01-17-2005, 09:42 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Try pouring some ATF in the carb at a high idle. Not much, just a trickle and have the engine fully warmed up and running at about 1200 RPM or so.
Old 01-17-2005, 09:43 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
If you need a pair of heads, i have a pair of #624 heads with about 25,000 miles on a rebuild. They are fine and not cracked.....76cc, but 1.72/1.50 valves. Hardened valve seats too. $50 plus shipping and they are yours if you want them....shoot me a PM if you need them.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-17-2005, 10:25 PM   #6
jostrans68
Jostrans68
jostrans68's Avatar
yellow i will keep it in mind longhorn it sticks so bad it throws the rocker off I am going to pull it tommorow thanks
[CGTW Member
Old 01-17-2005, 10:46 PM   #7
vk_chevy
vk_chevy's Avatar
I have a set that I just pulled to replace with early fuelie heads. I am in olympia and you can take a look at them if you are interested.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 01-17-2005, 10:52 PM   #8
jostrans68
Jostrans68
jostrans68's Avatar
what kind of shape and price? hoping to find a bolt on one thanks
[CGTW Member
Old 01-17-2005, 11:04 PM   #9
vk_chevy
vk_chevy's Avatar
I think they are in pretty good shape with Erson springs. You can have both for $75.
65 Jag MKII
Old 01-18-2005, 02:36 AM   #10
jostrans68
Jostrans68
jostrans68's Avatar
by chance do you know the casting numbers? sorry to be a pain Jack
[CGTW Member
Old 01-18-2005, 10:02 PM   #11
vk_chevy
vk_chevy's Avatar
looks like the casting number is 462624, granted, not the best flowing head that GM ever made but is fine for those that are not looking to break any speed records...
don't get me wrong, I am not trying to dump these heads on some one, I've got 2 other motors that I'll be building in the next year or so and I can use them myself for those "stock" rebuilds
65 Jag MKII
