Old 01-18-2005, 12:34 AM   #1
low 84
low 84's Avatar
dash lights blowing fuses
the dash lights in the '80 4x4 keeps blowing their fuse. i can put a new fuse in and they will come on when the headlight handle is pulled and the ignition key is in the off position, but when i start the truck the fuse will blow.
any ideas whats causing the dash lights to short when i start the truck?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-18-2005, 05:05 AM   #2
Blue Beard
Blue Beard's Avatar
Thread on problem similiar to this earlier. Upon checking the trailer wiring found the PO had used tape on the connection and the tape slid off exposing the wiring to short.
Just a thought.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-18-2005, 01:26 PM   #3
low 84
low 84's Avatar
was that casuing just the dash lights to short or all the lights? the dash lights are on a different fuse than head and tail lights and my headlights and taillights are working fine
'05 1500 Crew Cab
RIP
Old 01-18-2005, 03:50 PM   #4
blink32
blink32's Avatar
Just going off what your describing it *might* be in the power circuit that powers the warning/indicator lights that your check engine type lights since it doesn't happen when the key is in the OFF position but it does when its in the other positions.
I do know that some(if not all) of the power for the printed circuit on the back of the gauges relies on power from your headlight switch. And at that point it ties in with grounds and power from other circuits so if there is malfunction in other circuits it could be an issue there.
I would pull the cluster and just take a look at the printed circuit. If everything looks find and no burnt wires I think the next step is to break out an ohm/multi- meter and start testing wires. Use the factory wiring manual and unplug the plug from the gauge cluster and start there. If you still blow the fuse after unplugging the cluster you'll know its before the cluster.
Took me a while to diagnose why I didn't have any dash lights at all and ended up being a bad headlight switch along with a bad printed circuit on the guage cluster.
blink32 is offline   Reply With Quote
Old 01-18-2005, 05:47 PM   #5
low 84
low 84's Avatar
thanks man, i didn't think about the printed circuit, there might be a wire shorting to it, i'll have to look at it. i'm about to swap to a tach cluster so mabey when i do that it will get rid of the problem
'05 1500 Crew Cab
RIP
Old 01-18-2005, 06:11 PM   #6
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I have had the same problem and upon closer inspection I also had a short on the harness leading to the taillights. The dash lights are on the same circuit as the running lights.
NeCrOmAnCeR is offline   Reply With Quote
Old 01-21-2005, 12:00 AM   #7
HAZBRZ1
Once the wire to my glove box light got pinched and I blew fuses immediately until I chased wires and found it. If it just recently started a wire somewhere may have been pinched. Spent days trying to figure it out and felt pretty stupid after I figured it out. Good Luck
HAZBRZ1 is offline   Reply With Quote
