Old 01-18-2005, 05:38 PM   #1
69ChevySWB
69ChevySWB's Avatar
Parts for Sale (DFW Area)
All of these parts are off of a 69 Chevy 1/2 Ton.
Pics
AC Cab - Needs Rockers and floor work. No VIN/Title. Pictures show as tank and rearview mirror. Both have been removed. Seatbelts will stay (Blue). $150.00
SWB Bed - Passenger Bedside only part that may be repairable. Has a lot of pitting. $25.00
Glovebox Door - $10.00
Spare tire mounting parts - Has pitting. $15.00
Front Spindles - I have two sets. One set is missing parts. The other is complete. $10.00 for set missing parts and $20.00 for the other.
Brake/Clutch Assembly - $15.00
E-Brake Assembly - $5.00
Hood Hinges - $5.00
Drivers Side Green Visor - $5.00
Green Arm Rest - $10.00
2 Hoods - Hood 1 is $10.00 and Hood 2 is $25.00
Steel Bumper - $15.00
Upper and Lower Control Arms - I have only finished cleaning the upper. The lowers will look the same when sold. They are wire brush cleaned, sprayed with rust-oleum heavy rusted metal primer and foam brush painted with rust-oleum oil-based black gloss. $75.00 for all four (SOLD)
73-87 Engine Mounts - Same cleaning and paint as the control arms. $20.00
6 Lug coil rear end - Not sure of ratio. I tried using the FAQ of spinning the wheel once and count the driveshaft turns. The yoke spun 2 times for each 1 wheel revolution. $25.00
I will ship the smaller items but would rather not ship the larger.
Brian Thompson
99 2500 Silverado 6.0
05 Suburban (Wife's)
67 Mustang (Wife's)
69ChevySWB is offline   Reply With Quote
Old 01-18-2005, 06:06 PM   #2
David Johnson
David Johnson's Avatar
You have a PM about the SWB
David Johnson is offline   Reply With Quote
Old 01-18-2005, 06:15 PM   #3
69ChevySWB
69ChevySWB's Avatar
I also have a LWB frame that has been stripped. $25.00 if interested.
Brian Thompson
67 Mustang (Wife's)
Old 01-20-2005, 12:11 AM   #4
69ChevySWB
69ChevySWB's Avatar
Anyone????? I will also take resonable offers.
I have also have a non-tilt auto column and a set of front coils.
Brian Thompson
67 Mustang (Wife's)
Old 01-23-2005, 02:30 AM   #5
mcubedntx
mcubedntx's Avatar
PM Sent
Just a NOVICE who thinks this is the BEST board on the WEB!!
mcubedntx is offline   Reply With Quote
Old 01-23-2005, 04:04 PM   #6
2low72
Interested in the control arms. how far are you from ft. worth and could you send pics to calebs02@cox.net
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 01-23-2005, 06:16 PM   #7
69ChevySWB
69ChevySWB's Avatar
Responded to PM and sent e-mail.
Brian Thompson
67 Mustang (Wife's)
Old 01-27-2005, 04:50 PM   #8
69ChevySWB
69ChevySWB's Avatar
Ttt
Brian Thompson
67 Mustang (Wife's)
Old 02-11-2005, 05:15 PM   #9
69ChevySWB
69ChevySWB's Avatar
Trying one more time
Brian Thompson
67 Mustang (Wife's)
Old 02-11-2005, 07:53 PM   #10
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I take it that the frame has even been stripped of the front crossmember.?
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 02-11-2005, 08:18 PM   #11
69ChevySWB
69ChevySWB's Avatar
bagged69, I sent you a PM
Brian Thompson
67 Mustang (Wife's)
