01-18-2005, 07:28 PM | #1 |
Welds and Mickeys for sale
Front: 15x5 Draglite xp's. 2 1/2 inch backspacing with 28x7.50 M/T Sportsman front tires
Rear: 15x10 Draglite xp's. 5 1/2 inch backspacing with 29.5x 15.5 M/T Sportsman pro tires Bolt pattern is 5x5 Only rolled around the shop a little. $700 + shipping Thanks, Dan |
01-18-2005, 07:44 PM | #2 |
I am interested ,do the rears fit without mods to the truck thanks JOHN
01-18-2005, 07:52 PM | #3 |
In the picture they are mounted on 72 axels, and there is not much clearance on the inside or the outside. About 3/4 to 1 inch on the inside, and a little more on the outside. I have the shorter rearend housing out of a `67. I was going to get some new axels with the 5x5 pattern,and cut a couple inches for some mini tubs. Then I think they would fit nicely.
Dan |
01-18-2005, 07:57 PM | #4 |
so what your saying is the way they sit now they might rub without the modifications you describe,on a truck with a stock stance,or a 4 inch drop.
01-18-2005, 08:06 PM | #5 |
That is a possibility. I have adjustable coilovers on the rear, and if I let them down it looks pretty close.
Dan |
01-18-2005, 08:10 PM | #6 |
Thanks ,Dan I will pass on them.but for anyone else looking at these combos I did the math and Dan is selling these for nearly $700.00 less than what you would pay new.
01-18-2005, 08:14 PM | #7 |
Thanks John.
Dan |
