Old 01-18-2005, 08:19 PM   #1
teamharvey
teamharvey's Avatar
SB to BB Swap questions ?
Ok,
In a perfect world I would like to swap the 350 for a big block. I have a 72 4x4 blazer and was wondering what major obstacles I would be looking at as far as mounting ect.
Thanks,
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 01-18-2005, 08:22 PM   #2
454_72_4X4
454_72_4X4's Avatar
auto or stic trans?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-18-2005, 09:43 PM   #3
Nick's683/4
I am in almost done with mine and it hasnt been to bad. The only thing i had to do was to cut the fire wall for my valav covers. Here are some pics. There is some outher suff you need to do just let me know if you want to do this and i will tell you all that i had to do.
70 1 ton with a 454 and a 4 speed and a np205
Nick's683/4 is offline   Reply With Quote
Old 01-18-2005, 10:31 PM   #4
kwmech
Years ago when I did my 71, I didn't feel like cutting the firewall or doing a body lift [I hate body lifts] so I moved my x-member forward and redid the drivelines.
Old 01-18-2005, 10:41 PM   #5
teamharvey
teamharvey's Avatar
Originally Posted by 454_72_4X4
auto or stic trans?
Auto trans.......
1 incredible wife
2 great kids
Old 01-18-2005, 11:07 PM   #6
Nick's683/4
i was going to move the x/member but i didnt have the money for the drive shafts
Old 01-19-2005, 12:42 AM   #7
kwmech
Mine were worn out at the time so it didn't matter much. Nothing like a worn out slip yoke and small dings in the tube with a fresh big block, didn't want any problems when I stomped on it.
Old 01-19-2005, 12:13 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's some info I put together based on my big block swap into my 69 K20.
Big Block into 69 K20
Nothing like a tight fit.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-19-2005, 12:58 PM   #9
454_72_4X4
454_72_4X4's Avatar
Here's a couple of pics of my firewall mods;
Right side
Left side;
Clutch linkage;
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-19-2005, 01:13 PM   #10
454_72_4X4
454_72_4X4's Avatar
Here's a couple of the "54" installed;
I'll be switching to a hydro clutch soon I hope. I'm gonna be putting in a NV4500 5 speed and the only way I can afford to get it in there is to go with a hydro clutch system.
Yukon; What is your clutch master cylinder originally for?
How did you figure where to put it, (so you'd have enough travel and whatnot).
Do you know the bore size of it?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-19-2005, 08:42 PM   #11
teamharvey
teamharvey's Avatar
Great info....thanks guys.
Bret
1 incredible wife
2 great kids
Old 01-20-2005, 03:58 AM   #12
4x4Poet
I once read in a now defunct mag (4x4Now?) that one can use a 73-87 engine crossmember to install a BBC into a 67-72 K10/K20. Only need to drill one hole top and bottom each side and the other three holes each side line up with existing holes to guide the drill locations. The 73-87 xmember helps one use clamshell motor mounts and most BBC oil pans. No other mounting mods needed. I haven't seen this done, though. Unverified info.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
