01-18-2005, 08:27 PM | #1 |
VIN decoding help
A friend of mine has a 70-71? truck we've been trying to decode the VIN #'s.
It doesn't seem to match any of the "decoders" we've found, (including here). Can anybody help us out on this? Here's what the tag on the left door has; KE234-SZ@#$%^ Thanks
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-18-2005, 08:43 PM | #2 |
2A674 Tank Rat
Here is my try at it: If I am wrong someone please correct me.
K = 4 x 4 E = V-8 Gas 2 = 3/4 ton / 5200 - 7500 lb. 34 = Cab - pickup box (for GMC anyway I assume it may be) could be wrong here. S = built in St. Louis Z = 1970 for 15 Series Ok this is my try at it, hope I win the big cookie and this helps. Mike
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
01-18-2005, 08:46 PM | #3 |
KE234-SZ@#$%^
Simple K = 4x4 E = eight cylinder 2 = 3/4 ton 34 = fleetside box S = St. Louis assembly plant Z = 1970 It's a 1970 3/4 ton 4x4 GMC fleetside box pickup. Not sure where above post got the Z= 1970 15 series...that ( 15 series) is the only thing wrong. Good got someone else to do these now..your faster than Longhorn Man now . And you even beat me to it.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
01-18-2005, 09:30 PM | #4 |
Thanks guys.
The "-" between the "34" and the "S" had us bumfuzzled. All the decoders seem to show the year number to come after the "34" and he just has the "-". The only "Z" code I could find means Fremont assembly plant but it has the "S" for St. louis plant so I didn't know what was going on. Thanks again.
01-18-2005, 09:41 PM | #5 |
70 and 71 GMC vins on some asembly plant lines did it differently like in your case.
The Z still means Fremont plant on many other variations of vins.
01-18-2005, 09:50 PM | #6 |
His truck is supposed to be a Chevy! It has a Chevy grille and tailgate anyway.
Could be the cab has been changed?
01-18-2005, 10:02 PM | #7 |
Try to match the cab vin with the frame vin and compare.
01-18-2005, 10:07 PM | #8 |
My 67 gmc has 15 digits in the vin????????????Can anyone decode mine???? I dont want to jump on anyone thread but it is a good one.
CM3640VCZC***** This is a V6 truck and cab and chassis dually |
01-18-2005, 10:12 PM | #9 |
not a problem bring it on bisquik65
oh, its there..hmm...thats gonna take bit,..check back in a few
01-18-2005, 10:25 PM | #10 |
According to my 70 owners manual: C-96" or 106" conventional cab, M-V6 gasoline,3-6700-10000 GVW, my manual lists a 62 code for body and brake vs your 64; Chassis-Cowl (Full Air), the 0 digit denotes 1970 according to my owners manual so I am lost after this point. Hope this helps a little bit
01-18-2005, 10:28 PM | #11 |
CM3640VCZC
Gee I dont know ..I saw one like this also..except it was a 4x4 and was KM2whatever..I cant even find the number anymore. Anyway C= conventionall cab M= v6 gas 3 = 1 ton gvw range 4? dont know 0V = cab and chassis C = 1967 Z= fremont plant C= dont know Its like GMC put model numbers for vins ..this makes more than a couple I've heard of like this.
01-18-2005, 10:31 PM | #12 |
Where do I look to find the frame #?
01-18-2005, 10:33 PM | #13 |
I believe this was an EZ HAUL truck that had little eleaphants on the box sides? its is blue and white. It was compatition for U-haul back that era. Not sure. It had a 14 foot box on it that came over the top of the cab
01-18-2005, 10:37 PM | #14 |
Does it have air brakes? I'm trying to figure out what some of these abbreviations mean in my VIN decoder in the back of my owners manual?
01-18-2005, 10:37 PM | #15 |
Not tryin' to hijack the thread here but i'm having the same problem. The frame and cab #'s match, but the tag on the glovebox says CE234-ZZ51273, not sure what it comes back to???? Maybe a typo on the label or something I guess.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
01-18-2005, 10:40 PM | #16 |
I wa wondering if the last character on that vin bisquilk is a letter also.?
******B or like that
01-18-2005, 10:42 PM | #17 |
This thread rules. GMC vins are who knows???? This gmc does not have air brakes ,manual steering with 18.5 x 6 split rims. Old skinnies. 5.13 gears with a new process 4 spd with a spicer aux. trans (yea old twin stick) very cool for gas milage
01-18-2005, 10:44 PM | #18 |
Robert your is fine still
CE234-ZZ51273 C= Conventional cab E = 8 cyl 2 = 3/4 ton 34 = fleetside box Z = Fremont Plant Z= 1970 51273 ... means sequence number.
01-18-2005, 10:48 PM | #19 |
frame number is where Longhorn Mans finger is typically..top of rail.. should start with the year then assembly plant and rest of sequence vin.
01-18-2005, 10:49 PM | #20 |
No he is the whole thing on the title.
CM3640VCZC14558 thats all Mabya special vin for a fleet??? Did you get your rivits yet rod??? |
01-18-2005, 10:55 PM | #21 |
No vin rivets yet... mail is slow getting here from US.
I have to pass on figuring that vin bisquik..thats all I can figure for now...I'll write it down and see what I find.... it's one of those odd ones. I've got lots of peeps on this thread answering as I reload the pages. .lol There's a little better pic of vin on frame.
01-18-2005, 11:10 PM | #22 |
CM3640VCZC14558
OK this is what I figure it is bisquik65 I should charge for this... C= Conventional cab M = V6 gas 3 = 1 ton 64 = GMC way of stating cab to rear axle dimension..in this case 64 means 84 inches OV = cab and chassis order designation C= 1967 Z = fremont plant C14558 = GMC's starting serial number for trucks produced in USA in 1967 started with a C1*** you got number 4558 out of that plant or perhaps 14558.
