01-19-2005, 10:56 AM | #1 |
how much is it worth??
how much is a factory cruise setup with all the brackets and the turn signal lever worth? just curious..
thanks Rick
https://www.ebay.com/itm/295742064443 |
01-19-2005, 11:08 AM | #2 |
This, is my BOOMSTICK!
What year is it factory for?
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) |
01-19-2005, 11:52 AM | #3 |
1970
01-19-2005, 01:18 PM | #4 |
does it make a difference if it is a big block or not??
are the brackets the same???
01-19-2005, 01:33 PM | #5 |
Would need pic to see if it's correct first. You could always through it on ebay with a $100000 reserve and see how much it goes to, or get rich.
Your 70 vacuum pod should mount on the firewall and use a chain to carb. So no bracket is off the manifold, hence BB , SB are same. A complete system working should fetch $200 if your just wanting an amount. Were talking wiring harness to switch from servo, cruise activated lever switch, vacuum lines from brake pedal to servo. and lines to vacuum pod, T- fittings, vacuum pod, servo, switch off brake pedal and bracket that mounts it, chain, chain clip, mounting stud off carb to attach chain to. All I can think of off top of head. Missing something and it is hard to find correct part to make it work. But I'm talking more of a correct restoration.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
01-19-2005, 01:50 PM | #6 | |
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
01-19-2005, 02:04 PM | #7 |
