Old 01-19-2005, 11:37 AM   #1
BadAssChevy502
Yeh It's Fast
BadAssChevy502's Avatar
Question Will A 1977 lincoln versailles rear end fitt my truck
Ok this maybe a stupid question but I was wondering…………..
I can buy a rear axle from a 1977 lincoln Versailles now the man says it a 9 inch ford rear is this correct ,and also will it fit my 1972 C20 ???
Thanks in advance for all the your input
(I'm sorry if the spelling isn't correct,i'm trying the best I can )
1972 C20 3/4 Pickup Fleetside 502ci Th400
Click here to view pictures of my truck
1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox
"IF IT AIN'T BROKE DON'T TRY TO FIX IT"
Zwijndrecht,
The Netherlands
Europe
BadAssChevy502 is offline   Reply With Quote
Old 01-19-2005, 11:54 AM   #2
StingRay
StingRay's Avatar
I believe that car is Granada based. Better measure. I know the disc brake housings form the MK cars are almost perfect with the right bolt pattern axles and all. The ratio's are usually quite high in them though.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-19-2005, 12:14 PM   #3
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
If I remember correctly there is a 2" total difference, so that would be 1" on both sides shorter. The bolt pattern is supposed to be the same 5 on 5. I'm not a f52d guy so please double check me on this, but I looked into it a few years ago and even found a rear, but decided it wasn't worth the price and work. ......Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 01-19-2005, 12:15 PM   #4
junkyardjohn
junkyardjohn's Avatar
I'VE GOT A NINE INCH OUT OF A 75 MKIV. IT HAS DISCs & A 5 ON 5 BOLT PATTERN (SAME AS OUR TRUCKS). IT'S WITHIN AN INCH OR SO OF BEING THE SAME WIDTH. I TRADED A FRIEND (WHO OWNS A DRIVELINE SHOP) A BUNCH OF PARTS TO PUT A NEW POSI UNIT IN IT, & CHANGE OUT THE RING & PINION FOR 3.55 TO 1 GEARS. HE ALSO REPLACED ALL SEALS & BEARINGS. I HAVEN'T GOT THIS PROJECT ROADWORTHY YET, BUT IT SHOULD BE BY MID-SUMMER. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-19-2005, 12:59 PM   #5
jhow66
jhow66's Avatar
Better check the prices on parts for the Versailles(if you can find them).Ford does not carry parts for these any more.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-19-2005, 01:45 PM   #6
junkyardjohn
I'M NOT A FORD GUY BY ANY MEANS, BUT ISN'T A 9 INCH THIRD MEMBER OR CENTER SECTION THE SAME FOR A WHOLE BUNCH OF MODELS?? JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-19-2005, 01:52 PM   #7
StingRay
StingRay's Avatar
Yup as long as the spline count is correct for your axles any should fit.
Canada
Old 01-19-2005, 02:27 PM   #8
jhow66
jhow66's Avatar
Not talking about the stump--calipers. rotors, brackets,parking brakes parts, etc.. I know because my son-in-law just got one to try to put in his 56 Chevy. Found out you cannot shorten axles or find parts for the items I listed. Any one want to buy a good Lincoln Ver. 9" disc brake rearend? CHEAP!
Old 01-19-2005, 02:51 PM   #9
Shane
Shane's Avatar
the Versailles rear is the rear of choice for the Street Rod crowd ... so much so that they are dang near impossible to find anymore.
Shane is offline   Reply With Quote
Old 01-19-2005, 03:39 PM   #10
1969 GMC
1969 GMC's Avatar
uhh...are you gonna carry two spares? or are you converting your front suspension to 5 lug?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-19-2005, 03:45 PM   #11
72402
That's right, street rodders like'em for the width, only an inch or so wider than the early mustang. I'm not positive, but I thought they had 5 x 4 1/2" bolt pattern.
72402 is offline   Reply With Quote
Old 01-19-2005, 05:31 PM   #12
BadAssChevy502
Yeh It's Fast
Hey thanks all
Hey thanks all for your quick answers i was thinking of converting to 5 lug if the axle should fitt.
The guy is asking 200 (is that to much??) dollars for the axle,and is not sure if it is A posi,he's getting back to me on that ,and also on the dimensions .
Can anyone post A picture off this axle so i can compare them to see if it's the correct one
Thanks in advance
Zwijndrecht,
The Netherlands
Europe
Old 01-19-2005, 07:17 PM   #13
Vince Putt
Hippy
I have a one of these rears. They are approx 55" bmeasured back of rotor to back of rotor. I'll check to make sure if you really want me to. They are 5x 4.5 bolt pattern. they use a tapered axle so they can't be shortened. I original bought it to go in a 70 z28 many years ago. it was too narrow to clear the leaf springs. Latter I used in in my 85 pro streeter. It will go under the 67 we're building now. $200 is a good price you can easily sell it for that much to the street rodders like Shane & 72402 said.
Vince Putt is offline   Reply With Quote
Old 01-20-2005, 08:25 AM   #14
BadAssChevy502
Yeh It's Fast
Pictures Anyone???
Can somebody please post some pictures ?
Zwijndrecht,
The Netherlands
Europe
Old 01-20-2005, 09:16 AM   #15
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'd have 8 lug front wheels and 5 on 4 1/2 car pattern rear wheels.
Also, if your truck is a coil spring truck, you'll have to do some mods to get the panhard bar mounted to the rearend as well as the spring pad change.
Old 01-20-2005, 10:20 AM   #16
bigjimzlll
bigjimzlll's Avatar
on a ford 9" the bottom bolts on the center section can not be removed with a rachet and socket...on a 8" they can
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-21-2005, 11:50 PM   #17
jhow66
jhow66's Avatar
Thanks in advance
Here you go BAC502
Old 01-21-2005, 11:52 PM   #18
jhow66
jhow66's Avatar
One more:
Old 01-22-2005, 02:01 AM   #19
Bamm
Bamm's Avatar
My bad on the bolt pattern, so it must be the Mark IV that had the 5 on 5 pattern?
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 01-22-2005, 11:56 AM   #20
ABHaulR
ABHaulR's Avatar
rear end
if you have 8 lug now, you can get a 14ff and convert it to disk brakes. its pretty easy. you then dont have to change you front end to a different bolt pattern,(No FURD parts) LOL....
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 01-22-2005, 12:43 PM   #21
junkyardjohn
Dwayne
I'VE GOT A 14 BOLT FULL FLOATER THAT HAS BEEN CONVERTED TO DISCs. $300 FIRM & NO SHIPPING. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-22-2005, 03:38 PM   #22
rage'nrat638
rage'nrat638's Avatar
a little work it will look like this
rage'nrat638 is offline   Reply With Quote
