Old 01-19-2005, 11:56 AM   #1
85chevy
diesel question
Never owned or worked on one till now. We had a hard freeze Tuesday night and the thing won't start now. It worked fine before, and it spins over now. It tries to start but won't catch. Could bad glow plugs cause this? I'm almost certain that is the reason, but wanted to know if anyone had any other suggestions?
85chevy is offline   Reply With Quote
Old 01-19-2005, 12:00 PM   #2
Prerunner1982
Prerunner1982's Avatar
it could be bad glow plugs or the glow plug controller. If its hard to start carry some ether (starting fluid) with you.. dont use it too often but every once in awhile wont hurt. if you continue to have problems starting it... then its most likely a glow plug issue.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-19-2005, 12:50 PM   #3
60-66 Nut
Professional Beer Tester
Be careful if you use ether, it can be dangerous on glow-plug engines. It's not hard to check to see if the glow plugs are working. If the "wait" light comes on and then goes off after a few seconds, then you know at least part of the system is working. To check to see if the power is getting to the plugs, hook a 12V test light to the wire at the glow plugs, then turn the key on. The light should come on then go off when you hear the controller and relay click. To check each glow plug(key off), unhook the wire from it then clip the test light to the +pos on the battery and touch it to the terminal on the glow plug. If the light doesn't come on, then the glow plug is burnt. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-19-2005, 06:21 PM   #4
1986Silverado
What I drive
1986Silverado's Avatar
How hard of a freeze are we talking about? The diesel fuel could be gelled. Just my .02
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 01-19-2005, 11:37 PM   #5
85chevy
Thanks for the advice guys. I got a friend to check the plugs and half of them were bad. It starts good now.
Old 01-20-2005, 12:46 AM   #6
plumbcut
california fill
wow, my money was on fuel system.. interesting
pc
plumbcut is offline   Reply With Quote
