01-19-2005, 02:37 PM | #1 |
Senior Moment
? for you Transmission Guys
My 350 torque converter would not bolt up to my 454 flexplate so I drilled new holes.
My Question is Can I put a 400 torque converter in a 350 trans so it will bolt right up ??? If so would there be a differance in stall speed, Good or Bad??/
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 01-19-2005 at 04:02 PM. |
01-19-2005, 05:02 PM | #2 |
its all about the +6 inches
Yes you can install a TH400 converter into a TH350, that is how I hooked up a TH350 to my caddy big block.
As for stall...I've been told by some, that it would increase stall...and by others that it would DEcrease stall....NFC, I know it moves, and doesn't do anything stupid. I would highly consider getting another 454 flexplate. Really isn't a good idea puttin holes in there. |
01-19-2005, 05:25 PM | #3 |
Senior Moment
Thats why I'm askin, I didnt like drilling the holes either but it was right at the time if you know what I mean. I really like to know what if any differance there is in the Stall. The engines coming back out for another reason and I'd like to do it right.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-19-2005, 08:24 PM | #4 |
If there is, I highly boubt it's noticable. Like I said, mine feels right. A stock converter, and it feels...stock. When i floor it, it flashes a little stall, but it'll idle across the parking lot no problem.
01-19-2005, 08:39 PM | #5 |
Chevy Nuttttt
A th400 converter will be fine I ran one on my th350 in my k5. as for stall a converter will stall at a lower rpm with a sb than a bb. find your self a Trans Star store. they are who the trans guys get their parts from.
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
01-19-2005, 08:53 PM | #6 |
hi guys I was just reading your thread and unless you know your holes
are dead even your going to get a vibration which will do all kinds of bad things. so I'd get that out a.s.a.p. tork coverters stall at what ever r.p.m they were made at, stocks are like 1000 to 1200 r.p.m or so.I wouldn't swear to this but most start to roll just off idle. Now you can always buy a true stall coverter from sumit or jegs but don't go to high into the r.p.m's because if your town cops are like the ones here in wellington ohio just going down the street will get you a ticket! A friend of mine has a pro street nova with a 3000 r.p.m stall(more strip than street) and ever time it shifts it churps the tires. hope this helps if not, oh well. |
01-19-2005, 09:36 PM | #7 |
Stall speed
Stall speed on any tourgue converter is strictly a function of the tourque put into the converter. standard converters (stock) are designed to stall at about 1000 to 1200 rpm behind a stock engine. Higher stall converters are designed to move the stall speed up in rpm range as more tourque is applied to the converter. This allows you to take better advantage of the "fat" part of the engines tourque curve, which will result in better launchs.
Replace that drilled flex plate asap, you can get an sfi approved flexplate for under $50 |
01-19-2005, 10:55 PM | #8 | |
Still drivin' a Rat Rod
As far as the stall of the 400 converter in a 350,you might get a couple hundered RPM,nothing to write home about,and if you have any power at all you prolly won't even notice it. I do agree,swap that flexplate ASAP.better safe than sorry.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
01-20-2005, 12:46 PM | #9 |
Senior Moment
Thanks guy
I'll be heading down to my Tranny Guy to get the right converter
