01-20-2005, 02:16 AM | #1 |
Not Mine But A beauty
Droping Question
Im Looking At Droping my truck in the front and rear ive decided on 4 in the rear but im unsure if you have to have drop spindles in the front or you can just buy the lowering springs in the front any help is appreciated
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
01-20-2005, 02:23 AM | #2 |
Just depends on how far you want to go in the front. You can go with just springs or just spindles or both, depending on how far you want to go.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
01-20-2005, 07:56 AM | #3 |
woodman13
I dropped several 67-72 SWB and LWB trucks and I have used several methods. A 71 LWB I used 2" drop spindles and 1" drop coils on front with new shocks and 4" rear coils and new shocks(don't remember the name of the parts, but all came from Godfather Customs). It had a nice ride and looked sweet. I then dropped a 69 SWB with 3" front springs and 5" rear springs with new shocks frt and rear. It also has a nice ride and was cheaper to do. Neither truck wears tires more than the other or has went thru any abnormal parts changes like ball joints or tie rods. My next truck(71 Sub) I want lower, 5-6" in the front, so I will use air bags.
Woodman13 2007 Dodge Ram 3500 5.9 rolling coal! 1994 Caprice 9C1 88K miles, LT-1, dropped/shaved 1967 C-30 350 4 sp dually 1971 C10 SWB BBC, auto; good driver |
01-20-2005, 05:41 PM | #4 |
thanx guys i was thing along the lines of 2-3 in front and 4 in back
01-20-2005, 06:14 PM | #5 |
I would personally use the drop spindles. They drop the suspension perpendicularly. Drop coils change the suspension geometry slightly, which I'm sure an alignment shop could compensate for. IMO I'd use spindles. You didn't mention the year of your truck but I'm guessing 71, if not, now would be a perfect time to use spindles to convert to disk brakes. Spindles are a little more pricey, it's up to you, but I think they make 2 1/2 drop spindles now. A 2 1/2 front and 4" rear drop would look good. JMHO. Good luck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-20-2005, 07:58 PM | #6 |
yeah i was just readin up on that is the traction bar on the rear end really need replacing if you lower the rear? yes my truck is a 71 Cheyenne
01-20-2005, 08:23 PM | #7 |
71 DELUX
It is a simple thing to do, from one 71 longbed owner to another...
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
01-20-2005, 09:10 PM | #8 |
YA YA
Another 71 cheyenne owner here, I just dropped mine 3 in the front and 4 in the rear using springs. Following the advise of another board member I used two jacks (one to jack up the truck the other to lower the control arm), removed the two ubolts holding the control arm and slowly lowered the control arm until the spring safely dropped out. Alignment was fine. I didn't even have to remove the front tires. Although, I plan on changing the rear to 5" or adding a 1" lowering block so that'll it set level. Good luck. Jim
Jimbo '72 SWB - 350 (frame-off resto in progress - donations accepted) '04 Chevy Avalanche '03 Cadillac CTS (wife's ride) Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707 |
01-21-2005, 01:31 AM | #9 |
looks great jim so you had no problem with the agles or anything ?
01-21-2005, 01:46 AM | #10 |
C10 Club Tennessee
Don't mean to steal the thread, but I was told by Jeff at Classic Performance that since I have 4 inch drop springs in the rear, but since I want 6 inches I could use 2 inch blocks, andybody? Bueller
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
01-21-2005, 08:08 AM | #11 |
YA YA
71Longbed - I really can't believe the difference it made in handling, I bought a sway bar from Bamm and was in a hurry to get it on but now I'll put it on when I get around to it. Once I get new tires and rims I'll still mostly likely get an alignment but in no way in a hurry because I can't tell any difference.
Yellow69 - Same here, I plan going 1" lower in the rear and was told by a performance dealer to use a 1" block. Although, I do have one issue but don't think it is a lowering issue. When my truck is in gear with the brake applied I can hear almost a slight grinding noise (doesn't do it when it's in park or neutral). I just had the tranny rebuilt so I was gonna take it back to the guy and let him look at it. Has anyone had this issue when lowering?
Jimbo '72 SWB - 350 (frame-off resto in progress - donations accepted) '04 Chevy Avalanche '03 Cadillac CTS (wife's ride) Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707 Last edited by Jimbotronics; 01-21-2005 at 10:04 AM. |
01-21-2005, 09:20 AM | #12 |
When y'all are lowering your trucks, are you using a kit that compensates for the rear pinion angle? I've seen the kit, it's a simple triangle block that fits between the rear end and the trailing arms. Jimbotronics, look under your truck to see how much clearance you have between the driveshaft and the trailing arm crossmemeber that the driveshaft goes through. It's possible it is clearing it when sitting, but suspension travel as your going down the road may cause it to hit the top of that crossmember. Check your driveshaft for a new silver ring around it (scuff marks from hitting x-member) Might be your noise.
01-21-2005, 09:45 AM | #13 |
YA YA
I'll check it tonight when I get home. I know noise is hard to pin point but from sitting in the seat it sounded to be coming from the tranny dust plate cover area.
01-21-2005, 09:50 AM | #14 |
Watch out for your cornhole !
Yellow 69, yes you can use a 2 inch block with your 4 inch spring to get a 6 inch drop. That picture of the lowering block I've posted so many times is on a truck with exactly that. He had it dropped 4 inches and I built the lowering blocks to get it down the last 2 inches. The picture should be easy to find.
No problems with doing it that way.
01-21-2005, 06:34 PM | #15 |
C10 Club Tennessee
Txfirefighter, Do you mind posting that pic for me or just tell me where it's at. Where can I get the 2 inch blocks.
thanks,
01-21-2005, 08:54 PM | #16 |
go to early classic's website they have lots of stance photos and sell quality parts that fit. Good luck
01-21-2005, 11:13 PM | #17 |
Yellow 69, here's the picture.
I made them out of rectangular tubing and just boxed the ends. I bought the u-bolts at a local truck spring shop for under 30 bucks. I just carried a stock u-bolt in there and told them to make me a set 2 inches taller. The truck in this picture is a 72 with 4 inch drop spring and 2 inch block with Early Classic shocks and adjustable track bar.
01-22-2005, 07:04 PM | #18 |
C10 Club Tennessee
